Post Info TOPIC: Tank selector under the van is no good for me :(
I have arranged the tank selector to be in the cupboard where all the filling and air hoses sit. Also included a flow meter to count the liters used. It looks a bit of a mess but need to be sure the proof of concept works.
Fortunately I finished the under van stuff after lunch just before the 20 mm of rain bucketed down!!biggrin
Heading to Warracknabeal Thursday for a Nephews wedding on Friday. Then taking a week to come home to regenerate Eril's and my batteries.nod.gif Should we use a 3 or 7 stage charger.biggrin
Aussie Paul. smile
Like the flow meter inline, great idea to keep an eye on usage and what really is remaining in the tank.
Vince
Cheers from Vince
VK2FBUZ
I would not be relying on a flow meter to extract every last drop of water Paul
I recently had the pump spitting a bit of air, when I was supposed to be about a quarter full
I assume it was the angle of the tank, so now I make sure that I do not go below a quarter of a tank
You ask what battery charger to use, not knowing what you have, set out below is my own system, which works for me, (using their spelling)
I have 2 X 120 AH AGM house batteries
I use a 5 stage CTEK D250S Dual DC to DC charger, where I use the engine alternator, and solar panel to charge the house batteries
The five stages are - Desulfatation - Bulk - Absorption - Float - Pulse
I carry a PROJECTA 240 volt, 15 amp battery charger, 7 stage switch mode, just in case
The seven stages are - Desulphation - Soft Start - Bulk - Absorption - Analysis - Recondition - Float
This battery charger give me the option of setting it to charge the following batteries
GEL - AGM - WET - CALCIUM - Or to use it as a 12 volt power supply
It also gives me the option of selecting the output current to be 2 - 4 - 8 - or 15 amp
Hope that this info is useful to you
KJB
Forget the trickle charge - just use short, heavy duty jumper leads .........................
KB
KB
Aussie Paul. smile
 Still laughing.... that joke was shocking!.
biggrin LOL. I shall pay that one Paul, sometimes I am too serious for my own good, and I forgot to read between the sheets. LOL again biggrin
 Hi Tony, I was having a joke re charging Eril and my batteries.biggrinbiggrinbiggrin
Aussie Paul. smile
Charge rate should be a minimum of One bottle of wine a night works for me to recharge biggrin
Our Rig
TUG 2017 Ford Ranger Wildtrak
