SmartBar Camp Creative
Post Info TOPIC: Mobile network modems and RSSI - very technical
If you are happy with the way your mobile phone/modem is working then this thread is not for you.
However if you are looking for a way to obtain decent resolution of the Received Signal Strength Indicator and set up various other involved aspects of your mobile connection then you may well be interested in this software:
https://mybroadband.co.za/vb/showthread.php/59080
I shall be making a 850MHz yagi soon as I discovered that connecting a 2m J Pole into the Telstra/Huawei E353T modem provided around 7db of gain which, in a bush mobile situation, is well worth having so a resonant beam antenna should do better.
MH
Did you read all 88 pages?
Sorry, I wasn't very clear at all was I :)
I was intending to point people toward the software he has written:
http://nerve.org.za/mdma/
Which will allow you to do all sorts of clever things with appropriate hardware.
And, following a friend's suggestion, I did a trawl of E-bay this morning and found the following 7 element yagi with 11dBi of gain:
http://www.ebay.com.au/itm/141732338192?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
For <A$15 I could not make it although I would have preferred two or three more elements.
If you do wish to buy one note that it is terminated in a female 'N' type connector and only has 30mm or so of tail.
