SmartBar SmartBar
Post Info TOPIC: Puzzling Water System Problem
2012 Jayco Sterling with slide-out
When we connect the hose to the water inlet, everything works fine.
However, if we do not connect the hose, and use the on-board tanks instead, then when I turn on the pump, the pump runs continuously (with all taps off) and water is squirted out of the outside hose connector. Turning a tap on and off makes little difference.
I am thinking a faulty non-return valve, but I have no idea where it is.
Anyone got any thoughts or ideas before I contact the service centre? Thanks in advance! confuse
The non return valve is either in the filler connection or part of the Pressure Reduction Valve.  This is a brass cylindrical object about 100mm long, it will be on the mains water hose just behind the filler under the van.
Give it a 'crack' with a hammer or such while the pump is running.  This may free it up.
If it does it may be time to dismantle it for cleaning or replace it with a new one.
Neil & Lynne
Pinjarra
Western Australia
Hi Almar,
In a standard Jayco plumbing config, the non-return valve is part of the pressure regulator assembly. It is most likely installed underneath the van, and is a brass unit about the same diameter and half the length of a 'red bull' can. The small non-return valve inside them can get stuck. You can disassemble and check for grit blocking the non-return, but be warned that to the uninitiated, the way these things are assembled does not appear totally logical - I wouldn't want you to end up with a bunch of parts and no idea how to put it back together.
Side note - it is my observation that the particle contaminants that are common in tap water can play havoc with these non-return valves (which brings up the separate subject of filtering incoming water).
Edit: Neil beat me to it :)
-- Edited by ants_oz on Wednesday 11th of January 2017 08:04:05 PM
Cheers, Anthony
Thanks for the info, Neil and Anthony. I'll have a look in the morning.  biggrin
Edit; also found some useful info down in the comments on this web page....
http://australiancaravans.com.au/library/11/2010/supplying-water-to-your-jayco/
-- Edited by AlMar on Wednesday 11th of January 2017 10:03:42 PM
Alan
We have 2013 Jayco Sterling Outback and experienced the exact same issue some time back. The culprit is "Non Return Valve' OR A John Guess Non Return Valve. Needs to be inserted in the line before the pump just back of the inlets valve.
I had the issue for several months and the head service person from Jayco Coffs Harbor gave me an interim fix. Use a Tap connector with a few centre meters of green hose with stop **** in the end. When you pull up at free camp or morning tea put the hose connector over the inlet valve outside where you normally connect your water hose and then turn on your pump. Works a treat and was only replaced when I had the Van serviced by Jayco.
Send me a PM if you need further clarification.
JohnR
"You have Gotta Love Your Jayco"
"House sitting Barmedman NSW"
TAJ
ALMAR   have the same problem  I put a ten cent piece in a hose fitting
             that screws on the tap  works for me was going to fix it 4 yrs ago
                         TAJconfuse
I was just thinking this problem through again, when I remembered the last caravan park we stayed at had the mains water turned off for a couple of hours while they did some work. I' wouldn't mind betting they introduced some muck into the system, and when they turned it on again, I copped some of the dirt in my supply, gumming up the works! Grrrr!
Anthony was on the money - filtration!!!!
I have a 6\7 inch Plastic screw on ends, garden water filter
on tap end of hose.
has a long internal filter, about 1 1\2 in Dia.
NO water goes in the van.
Without going through that first.
around $8. Cheap ins.
Plus I carry a plastic one way valve spare ($20).
Any blockages, I swap out. 2 or 3 min's with couple shifters.
and fix at own leisure.
No missus geeing me up. Water. Water.
Where's the Bl--dy Water.
They have several grades.
Mine is to remove "most" small solids, grasses.
Not bacteria etc.
Had this one around 10\12 yrs.
Clean with bleach occasionally.
It is about time Jayco got its act together and fitted a better quality NRV/PRV as numerous owners have been having trouble with them for the past 2 - 3 years
Bill B
Well, this morning I tried tapping the brass in-line Pressure Reduction valve, but no joy, so I popped round to the local plumbers merch and bought a new one, identical rating, for $72. Fitted that, and still no joy.
I went to the local Jayco dealer and they sold me a new inlet panel (which I needed as the plastic lock had fell to bits on the old one) for $69. The new hose connector DOES HAVE a built-in non return valve. The old one I took off didn't have it. I presume it had disintegrated internally and the debris was blown out when I ran the pump.
So, all fixed now, problem has gone away!
If this ever happens to anyone else, the plastic hose connector can be replaced in the inlet panel for just a few bucks, or as another caravanner stated, use a short piece of hose with a couple connectors with built-in shut off valves. Simple!!
And the moral of the story is... use an external filter!!! smile
I have a cap I take of the hose connector and put the cap on to seal of that part of the system other wise it sucks air and pump surges . Don't get to hook up to town water much so it don't worry me .
Dibs
gdyble
