Post Info TOPIC: satelite vast tv
satelite vast tv
confuseconfuseconfuse I have just bought a Vast satelite tv , it arrived last wednesday .I hav,nt set it up yet but have registed  it with vast. I have watched a few videos to see how to get it to work ,it could all end up being put away never to be used ,the instructions ????..Anyway my question is this ,is there a tv guide to see what is on a particular channel ,if so how or where do you get them . Cheers JOHN.confuseconfuseconfuseconfuse
  Atherton tableland Nth Queensland. Currently have a Crusader Manhatton ,But in april 2017 will be trading it in on a Retreat Brampton.
should be exactly the same as regular TV, if away just use the EPG (electronic Program Guide) button and scroll through the channels.
Peter and Robyn heritage
KFT
you can see a guide here for all of the states and all of the channels
www.sattvguide.com.au/
hope that helps
Frank
Avagreatday.
google   sattvguide.com.au
You say you have bought a system but haven't set up yet but registered it, well to register correctly you have to have the system up and running with the dish actually on the sat otherwise you have wasted your time and will have to do a re hit when you do get it st up.
It is a learning curve but not rocket science, go to a van park get the gear out and the helpers will appear like zombies ! some are great some a pain, but it will make it easier, but it is easy the second and third or fourth time and then you just do it without thinking.
brian
I agree with Banjo,
confuseconfuseconfuse How have you registered without been set up to receive your specific coded  number to your set top box, from Optus in the first place.confuseconfuseconfuse
Start all over please.
Regards Jim
-- Edited by Hey Jim on Monday 9th of January 2017 10:45:17 PM
-- Edited by Hey Jim on Monday 9th of January 2017 10:45:56 PM
I've just purchased my VAST TV kit and set it up for the first time this weekend. I had to admit being a total novice it was a bit daunting. On advice from Hugh at Satgear, I purchase a programmable satellite finder and he showed me how to set up the dish, lnb etc and it was far easier than I thought it would be. I had the set up channel showing within 30 minutes of set up (No doubt a lot slower than the experts). I haven't activated my card yet either, but Hugh said that the best thing to do was to set the system up at home so it runs the set up channel 800, then active the card. I think we have to re-active them every six months?
If I can set one of these VAST systems up anyone can. Mine came with well written instructions and that make the whole process a lot easier.
Best of luck but I'm sure the more you use it the easier it will get. I also have Satgear's mobile number to use at any time should I have difficulty.
Robbo.
R Thorn
