Post Info TOPIC: Scanguage 11 codes for TFT Mazda BT50 2016
Hi All
Hope you had a great New Year
I have the Scanguage 11 installed does anyone have this in there 2016 BT50 and what code do you use for the Transmission Temperature and is it easy to do as I am not very well clued in this area
Thanx inanticipation
Ron
Wombat56 Ron
RON.
if you have serious problems.
Contact the head office in States.
She couldn't be more helpful.
Actually wrote more codes for my 2010 D Max
as later models codes didn't work.
and sent in E-Mail.
None worked but that's just luck of the draw hey.
I should be able to download the manual from the internet. Just google "scangauge 2 manual" also "scangauge x gauge codes bt50" should have what you need.
-- Edited by Moonraker on Wednesday 4th of January 2017 09:30:16 PM
Hi,
Try this: (if you haven't already)
MAZDA CAN Protocol                                             TXD                    RXF                RXD           MTH                  Notes: All ATF gauges require ScanGaugeII with firmware version 4 onwards.
ATF Temperature for BT-50 (B32P/Q) 2011+    07E1221E1C    0462451E061C    3010     003F000A0000    5 cylinder turbo diesel models.
http://scangauge.com.au/x-gauge-commands/
X-Gauge is a feature of the ScanGaugeII that allows new digital gauges to be programmed in to the unit. Full instructions on entering X-Gauge codes in to your ScanGaugeII are are available in your user manual.
-- Edited by TheWanderer38 on Thursday 5th of January 2017 07:18:16 PM
THanks everyone for you replies
Wombat56 Ron
Thx The Wanderer38 will give t a go
Ron
Wombat56 Ron
