Post Info TOPIC: air conditioners
air conditioners
EC3 Portable 12 Volt Air Cooler / Evaporative Air Conditioner
Does anyone know anything about the above air con. Or any advice at all on portable air conditioners for a small caravan.
Cheers, albro
An evaporative air conditioner is basically a waste of time unless it is hot and very dry weather, they do not work in a humid environment.
It would probably feel cool if you sat directly in front of the airflow. though I think you would be much better off, if you kept the $300 it costs for this unit, in your pocket.
David
2 weeks in the northern heat and you acclimatise pretty quickly.
As for $300, I reckon that buys a lot of cold beers, and if there is a Mrs albro, that buys a lot of cold chardonays at the local airconditioned pub.
Thanks for the advice guys
Hello albro
I hope that I am not too late to welcome you to the forum
My wife has just brought a Transcool EC3F Portable 12 volt Evaporative Cooler, in the last few days
She mentioned $300, so it may be the one, or similar to the one, you are talking about
I shall report back in a few months how it went in the heat, and I shall give an honest appraisal
She probably already knows that it will not cool the entire interior of the motorhome, as on this coming trip, she commands that we take the generator with us
Looking at the literature that came with it, I would say that it is more a personal cooler for the individual, rather than a cooler for the interior of the RV
It will probably help with her sinus problem, as she does not like a stuffy atmosphere
I am at this stage completely neutral, as the cooler being an untested toy, I am neither for or against it
If it helps the Smart Woman (who) Must Be Obeyed, to get to like long distance travelling, then (for me) it is a good buy, regardless if it works or not
Friends have such a unit, or similar, and they say that it works fine for what it is. It's not as good as a reverse cycle, but quite satisfactory. Have the air blowing on you. They did say it is quite noisy. While away recently they used it as the day was quite warm; about 34C.
Di
BruDi
Thank you Tony and Di
