Post Info TOPIC: Newfangled alternator clutch pulley check and replace!
Hi smile
I was researching some information on my Mercedes Sprinter alternator and came across this little video. Short and to the point. If you are 'old school' you may not have noticed this 'advance' in alternator construction. I would think all new vehicles, particularly diesel will have one. confuse What appears to be a simple solid pulley that is expected to last a lifetime is no longer so benign. Water crossings, dust and hard use charging extra batteries would not be expected to improve the life of them. They can make odd noises too when failing, which are hard to locate.disbelief
 https://www.youtube.com/watch?v=fyosuYbPxr4
enjoy the accentwink
Thanks for this info Jaahn, it was something that I was unaware of
Yes, overrunning alternator pulleys.....
Had one fail on a previous vehicle (D40 Navara). Made one heck of a mess.
They can be replaced with a solid pulley, however these can cause issues with the alternator due to introducing different harmonics.
Cheers, Anthony
Youll find these on the modern variable voltage alternators.
Once the battery has fully charged (according to the vehicles ecm) it switches off the alternator and this type of pulley system allows the free wheeling of the pulley without any voltage output, less load on engine= better fuel economy!!
 Hi kezngaz smile
You are right in saying you will find these on the modern alternators. In fact all modern alternators AFAIK.
However your explanation of how it switches off the alternator and it freewheels is incorrect, I am sorry to say. The alternator continues to turn all the timehmm but it does switch it down to reduce the voltage output to save load etc.
The reason for the overrunning clutch is more complicated and involves the belt drive and cyclic fluctuations in speed. confuse I suggest people Google it if interested as they are a fixture on engines now.
My point in showing it is to alert some old hands, who may not think to look at the pulley when a problem arises. They never failed in the old days bleh but they do now.
Thanks jaahn, the more info out there the better. Thats what's so good with this forum.
Kezngaz.
