SmartBar Camp Creative
Post Info TOPIC: Mini caravan microwave - Sharp Carousel
Mini caravan microwave Sharp Carousel
Can be used inside or outside, smallest available with FULL power for perfect cooking
Works from 240v or 12v through a small inverter
Retro look
Good condition $288
Pick up Gold Coast
Ring John 0417044445
Happy Trails
John & Louise Green
Aust & NZ
Can we have a close up pic of the rating plate at the back please John.
Hi Peter,
I cant quote make it out from the pick either, we have it in store so i will need to go over there and have a closer look.
It works just the same as our regular one at home, its just smaller in size.
Cheers John
Happy Trails
John & Louise Green
Aust & NZ
Hi again Peter,
Its a 0.97 KW 600W 2-140DK
Hope this helps
Cheers JOhn
Happy Trails
John & Louise Green
Aust & NZ
No, that does not help.
We need a pic of the rating plate please.
This is what the plate says i'll send yo a pick
Thanks John
Happy Trails
John & Louise Green
Aust & NZ
Does this help? It's an American model but things should be much the same except for the voltage (and you should be able to work out the current at 230 F.) Click on the RH picture below the main picture.
John, is the microwave a 110 V model? I see you have a USA built van for sale also.
HI Peter,
No we have been using this microwave in our holiday unit on the Gold Coast [all the units have the same and some have been moved to vans], definitely 240v
It was purchased on the gold coast not the USA
Looks like the one for sale in the US but i can assure you this ones an 100% Ozzie :)
CHeers JOhn
Happy Trails
John & Louise Green
Aust & NZ
Hi again Peter,
Sorry for the delay, we are jus setting up our new Jayco on site in Southport
Pictures attached
Cheers JOhn
Happy Trails
John & Louise Green
Aust & NZ
Thanks John.
