Post Info TOPIC: Wiring alternator excitation circuit
The alternator on my old Chamberlain 354 originally had an external regulator. After a recent flat battery on the old girl, I discovered a later model alternator (Bosch I think) with a regulator (Ingram) attached to the back. I checked the alternator output while it was running, no charge the reading was the battery voltage. According to the drawing the excitation was initiated from the oil pressure switch. Well my old girl has an oil line to the oil pressure gauge; i.e. no electrical terminals. I plan to fit a new 3 way ignition switch with a new warning lamp for the excitation circuit. The alternator only has two wires off the back, how is the excitation circuit completed. I researched a few drawings on the net which showed both sides of the circuit, however unsure on the correct connection. Any auto sparkies out there with some advice please.
Oldgrey 52
https://goo.gl/images/vG80AGimage.png
-- Edited by Aus-Kiwi on Monday 31st of October 2016 07:19:08 PM
Show a picture of the back of the altenator if you want the correct answer, As there is atleast 3 different types of Bosch altenators.
D.L.Bishop
Check the above link .,
Thanks for the replies. I will be away until next week, I'll post a photo then. Regards Oldgrey52
This is a very common 2wire Bosch altenator on Fords & Holdens. Ingram regulators are after market reg.ALT. Circuit.JPGALT.2.JPGALT BOSCH.jpg
D.L.Bishop
Correction, the alternator is an Ingram, please see attached photo. So the D+ will be my connection to the new warning lamp on the dash?IMG_2635.jpg
Oldgrey52
ALT.1.JPGThe blue wire on your altenator is the one to fit the globe to & wire to ign switch. Its an Ingram copy of a Bosch altenator.
D.L.Bishop
Thanks DeBe,
once I have rewired,hopefully the alternator internals are in good working order.
Oldgrey52
oldgrey52 wrote:
Thanks DeBe,
Oldgrey52
Hi Oldgrey52,
That alternator is allmost older than you most likely. That firm went away years and years ago. Actually I think it got absorbed by Ashdown.  Why fit that unchecked and expect a good result.
Any wrecker would sell you an alternator 20-30 years later model for perhaps $20 off a Holden or Falcon and swap it if it did not work. What is the tractor worth to you. Just grief ??
-- Edited by Jaahn on Saturday 5th of November 2016 11:58:01 AM
I beg to differ on that I have one on my XF Ford panelvan. The main thing that will wear out is the brushes & they are easily replaced with out dismantling the altenator. A lot of later altenators have to be disassembled to replace the brushes. Those old altenators are very reliable.
D.L.Bishop
DeBe,
what is the spare terminal next to the D+ terminal in the photo?
Thanks
Oldgrey52
The spare terminal is a 7V feed for automatic choke, just disregard it.
D.L.Bishop
Heres the circuit of the altenator & description.ALTENATOR BOSCH.1.jpgALTENATOR BOSCH.2.jpg
D.L.Bishop
ISTR that some alternators had an extra terminal for controlling an electric fuel pump. If the alternator stopped turning, the fuel pump would cut out. Could that be another function of the 7V+ terminal?
Thanks DeBe.
Oldgrey52
