Post Info TOPIC: Jayco Conquest draws coming open
Usual disclaimer, that I am not a cabinet maker, and the only thing I know about wood, is that it is made from the same stuff as my head
There has been reports from other members about Jayco Conquest draws coming open
This fix may be helpful to others
Hopefully the pictures tell a story
This first picture is an original draw latch, with two home made ones, 3 mm higher next to it
Although the home made ones are only made from an old 19mm square 1.6 mm thick chair leg
The overall short measurement of 30 mm long with sides of 13 mm makes it too hard for me to bend
They should be suitable for keeping the draw closed, if the draw has sagged
This second picture shows that there is a bit of adjustment on the draw runners
After adjusting you may have to pack under the runner, to stop it falling down again
This will lift the draw button type lock, closer to the latch
Hopefully you will not find that the runner rollers are worn out
This third picture, tells the story of a frustrated fiddler
Thanks for posting this Tony.
Philw
The Happy Helper
Thanks Tony, will take a look and see what i can find in Boonah, think old mate around the corner can help me.
jules
(Ben, aged 10)
