Post Info TOPIC: Trailer break away switch
Hi All
 Having some thoughts about where I should attach the light steel cable to the tow vehicle for the break away switch?
I have put up a couple of photos, above and below the tow bar to help hopefully. A few things I have read don't give me a real answer.20160930_195635.jpg20160930_195544.jpg
Hi Radar,
I've been told the cable should be attached to the vehicle and not the tow bar. Reason being, if van snaps tow bar off breakaway wouldn't work.  You can also replace cable with a "coiled plastic coated thing" much better.
Cheers Owen
The only impossible journey is the one you never begin.
100 series landcruiser 22'6" traveller allterain.
OwenK wrote:
Hi Radar,
Cheers Owen
 Hi Owen
Yes, already have plastic coated coiled wire from the switch.
Yes, I agree the attachment point should be to the tow vehicle not the tow bar,
I may attach an extra fixed plastic coated wired of similar dia to the chassis of the ute with a loop at the end for attaching the coiled wire to when we have the trailer on.
I attach mine to the rear plastic bumper. Sounds simplistic but....it takes very little force to pull the plug and the bumper is totally separate from the towbar so no issue there. Cheers Neil
Neil & Lynne
Pinjarra
Western Australia
MY23.5 Ford Wildtrak V6 Dual Cab / 12/2025 Silverline 22.68.5
I fitted a plate with small eye on it to rear of ute to through bolt on rear spring hanger.
Crimped Stainless cable from there to tow bar. then crimped another eye there.
S/S cable from sw with small shackle mounts to that.
Van comes off ball. brake works. Towbar comes of ute. Brake works.
Covers both scenarios.
Basically just find a mount point on chassis rails or suspension
forward of towbar.
I gotta ask - how often have towbars separated from the vehicles? And why?
You'd have to reckon that a towbar fittment would be as solid as anything else, including suspension mounting points, wouldn't you?
Older veh's mainly.
Lotsa beach work.= Rusted chassis
Heavier van and a bit of negligence.
Whoops. No van.
Old again. Neglect. bolts unwind themselves over time.
=No caravan.
Home mad drawbar. Bad welds. = No Caravan.
Just a couple I've seen over the yrs.
Some.
BIG caravan. home made or LIGHT drawbar.
Whoops. No van.
Towbars are built and sold at different weight ratings.
Check the one on your veh if it came second hand.
I was caught once, decades ago.
Drawbar mounting IS one of your PRIMARY veh checks when towing.
BEFORE you start trip mainly.
They only Bolted on. they can come loose.
I always put locking tabs on at least 2 of my nuts
just to be sure. and a squeeze of Locktite on all.
Have watched the "Gall Boys " (Kedron Caravans) dvds, they lost tow bar on a Prado  (I think on Fraser Island), maybe because they had the WDH on vehicle in off road conditions. It is not recommended to use WDH on rough roads, so you can lose your tow bar although it would be rare.
Cheers Owen
 It used to be common with the early model OEM tow bar on the R51 Pathfinder.
Thanks guys. Mine is a Jeep supplied towbar rated to the max towing capability of the vehicle (3.5t). I had a look underneath today. It seems to be solidly mounted.
Thank you All
Will drill another hole in the chrome bumper and put in a eye bolt.
Added to the to do list.
Hopefully, neither your bumper nor the eye bolt will come loose and fall off...
Todays done it.
If I loose the bumper (decorative bit at the back) bar it really will be embarrassing moment.
The attachment point is now with trailer, anderson plug electricals and air points for the air bags, now if only I could get those annoying chains up high so I can see what I am doing instead of kneeling to fasten them to the to tow bar.
