Post Info TOPIC: Removal of silastic from van ensuite wall
Hi All,
Seeking some advice from all you knowledgeable people.
I have had to remove the hand basin (for a repair) in our combo shower/toilet and subsequently have silastic left on the wall and wish to remove same before reinstalling the basin.
I have tried a plastic scraper, useless.
Any ideas please??confuse
Thanks in anticipationbiggrin
Hurls
Mark & Chris
You are only young once but, you can be immature for ever.
A difficult one. Scraping is the only way. Try a "gem blade". It's a single edged razorblade or a Stanley knife blade.
www.diplomatblades.com.au/products_category.asp
You can get them at most hardware stores. Be careful, super sharp.
You can get a product that removes the problem 'gunk' from the big green shed. You apply the solution and leave for time stated in the distructions then just wipes off.
I have found the following items usually work on the silastic. Mineral Turps or nail polish remover (acetone). Both can be bought at Bunnings
-- Edited by dirvine on Wednesday 28th of September 2016 02:46:14 PM
David Irvine
Tugs: 2016 Discovery 4./2017 Toyota 76 GLX Auto Wagon. Van: New Age Manta Ray Deluxe
You can get a caramel wheel that will strip it off also.
Fit into a drill and use lightly.
There is a spray pack bought at Hardware/Bunnings that dissolves.
Messy but does job.
and I mean messy, have plenty of rags.
Done one recently used a very sharp blade scraped very close to the surface to remove has much has possible then used Drivine trick the trusty Turps , I would not use a power tool to easy to do damage .
Be very careful using strippers like acetone on plastics, acetone and similar, melt a lot of plastics, try it somewhere it won,t
be seen first
Having recently removed vast amounts of silicon and sikaflex during a recent caravan renovation I found that the propriety removers are not worth using (useless). The best job was done using mineral turps and scrapers made from icy-pole sticks obtained from Spotlights craft section. Make a square cut across the stick to create a beveled edge for the scrapers and use turps liberally. The turps causes the silastic to expand and lose some adhesion to the substrate, but hard labour and patience wins out.
Alan
give it a spray with brake cleaner, SUPACHEAP auto brand.
Dont know what is in it, certainly would not spray anything nearby and suggest you are wearing a full suit of armour and breathing apparatus. But boy, does it do a good job!
Wait 5 minutes and rub the silicone off
Try wd40 i found it worked on acrylic faced ply . Try in small area that will be hidden first.
Jeff
Living a life long ambition
Hi All,
Thanks very much for all the ideas. Ended up using a Stanley blade & turps. No scratches and NO blood!
Thanks agin
Hurls
Mark & Chris
