Post Info TOPIC: Hard wiring power outlets
RE: Hard wiring power outlets
Permalink Closed
If you have ever been involved in coronal inquiry ? The person responsible . God help you . I have been involved in two of them and I tell you it's no fun . I was the inspector, supply side . The other was earthing HV and the operater bridged the dead man lever in EPV . Trouble is the ground crew couldn't operate from ground when he got a static induction shock !! These guys don't miss anything when they inquire ! Trust me !! A few years ago on central coast a van had earth and active swapped at plug . Burnt off the main earth and livened up fence . Near killing young children when touching fence . Would you put an engine together ? With out checking ? No .. Yet it isn't as dangerous !!! Plus an electrocuted body smells .. I can't get it out of my head even after 20 years .. These accidents ( ??? ) effect far more than the actual person ..
Permalink Closed
I think we should be able to replace like with like fittings, IE, dble GPO with dble GPO.
Anyone that kills them self using it due to wrong installation only improves the gene pool.
Unfortunately it will probably be someone else that is killed.
Please, unless you are qualified, or know what you are doing, (don't need to ask a forum!) get it done by a professional.
Weedpharma
Permalink Closed
Boys, boys boys...
There is a passage in the good book that states "dont cast your pearls before swine" If realy silly people want to do their own wiring and not pay any attention to rules etc (oh and I forgot OHM'S LAW that has never been repealed). Then so be it. As an ex electrician you will not get one squeek of advice from me on how to kill yourself!
BTW I had a good laugh at some of the foolish posts on this thread.. FFS Get an electrician!!!!!
JEEEEEZZZZZZZZ!!!!
-- Edited by Phil C on Saturday 17th of September 2016 04:46:56 PM
Permalink Closed
rockylizard wrote:
Don't ya jest LOVE electrical threads?
YES
Especially when non qualified people give advise  on such a potentially dangerous subject.
Even worse ,when they insist they "know"
The sad thing is that many ELECTRICIANS are not aware of the Standard covering "Transportable Structures"AS/NZS 3001 & it's specific requirements that are in additional to the "Wiring Rules !!!
Permalink Closed
Also, while Im on the subject.
As a 6 year old kid my Dad (RIP) got me an electric train set for an Xmas pressy one year. Now the transformer had NO plug on the end for what ever reason (1956). I saw him poke 3 wires in the wall socket and switch it on and the train set worked.
I wanted to play with it early one morning. Poked in the 3 wires and blew the crap out of the transformer, blue the main fuse in our fuse box and more than likely the street feed fuse...
What you see is not what you get in electrical. PLEASE dont take the pee out of my old man. He stuffed up and could have killed me had I been hanging onto the metal case of the tranny.. EASY lesson here, dont get a 6 year old to wire your house or caravan.... BTW a 6 year old and a non licenced person have the same electrical skills set IMHO.
BTW Ive been an electrician most of my working life and IM STILL HERE!!!!!!
-- Edited by Phil C on Saturday 17th of September 2016 05:00:28 PM
Permalink Closed
robol wrote:
Dicko it would be better to use flex cable ( as noted on first page ) instead of the cable used in household fixed wiring. Flex will stand up much better to the constant vibration caused by travelling.
Cheers Rob.
 In my post I stated I use "stranded" cable. Had a family room extension wired up by sparky to cater for 8 power points, the cable used was the one in the photo...does not look like an extension cable to me but permanent and is flexible to withstand some movement as in a caravan. I use similar type cable for my odd jobs.
Cheers, Richard (Dick0)
Permalink Closed
Choice of cable is quite simple. If you have multi stranded cable with thin copper wire it will create more resistance. That creates heat. For internal wall wires the thicker the strands the better. As you increase frequency this becomes more important. At UHF frequencies the signal does not go down the inside of the wire it goes down the skin. So the reason you would not use extension wire inside a wall is the strands are thin to be flexible It is for temporary use. We all have horror stories. My one an old lady had a stroke and peed on an electric blanket and cooked her behind off, You don't forget that smell.
But if you look at most horror stories, They are accidents or they are stupidity. For example the government got the blame for people getting electrocuted putting in insulation. Knocking in staples on the top of rafters and going through a wire. Is it code for a wire to be on top of a rafter? no. Sparkies jumped up and down saying they warned the government, perhaps they knew how often that rule was ignored. In my house it was twice. Rob.
Permalink Closed
[1]If you have multi stranded cable with thin copper wire it will create more resistance. That creates heat
.[2]For internal wall wires the thicker the strands the better.
[3]As you increase frequency this becomes more important. At UHF frequencies the signal does not go down the inside of the wire it goes down the skin.
[4]So the reason you would not use extension wire inside a wall is the strands are thin to be flexible It is for temporary use.
Well part of above is partly correctbiggrin
[1]Multi strand cable with thin copper with the same cross sectional area of copper has exactly the same Ohmic resistance,as a cable with fewer but thicker strands.,or even solid copper  That applies with DC & normal mains power frequencies.
[3]Skin effect only come into the picture at high frequencies ,[the higher the frequency the greater the effect,' so is of no concern for general power use
That Skin effect is put to good use with high to ultra high frequencies for purposes such as induction heating,  silver soldering assembled components that have fillings that could be damaged by normal methods ,case hardening,  localised stress relieving of welded joint in critical applications
 For those sorts of applications ,the frequency can range from 2000Hertz to many mega Hertz ,[often using water cooled inductor coils ]
Yes, I KNOW because I have worked with & repaired such units
[2]With 240V  @ supply frequencies :
[a]It makes NO difference as far as resistance is concerned if the cable is multi strand or solid !
Single strand copper cable is now rarely used ,even in domestic situation, the norm is now multi strand
[4]  NO ,being thin  has nothing to do with the reason ,why it should not be used for permanent /fixed wiring,so you can keep guessingwink
Have You ever worked out why a say an 0 B&S cable [ 53mmx sectional area only has a continuous current rating of around 210A,yet a 20 B&S cable with around 1% of that cross sectional area has a current rating of  5A ??
-- Edited by oldtrack123 on Saturday 17th of September 2016 11:44:47 PM
Permalink Closed
YES , THat is NOT extension lead or classed as flexible cable
Standards approved multi core [twin & earth ,  plastic sheathed  [TPS] for permanent wiring ,under cover or protected from the elements.
Shall NOT BE USED AS A FLEXIBLE CABLE!!
This is FLEXIBLE  CABLE "'Flex Cable 2C+E 2.5mm2 50/0.25mm PVC Flex 250/440v O/Duty Grey "
good old "O/Duty " {ordinary duty },not even heavy duty ,GREY flexible cable, for such as EXTENSION leads & leads on appliances /devices etc
-- Edited by oldtrack123 on Saturday 17th of September 2016 11:42:16 PM
Permalink Closed
rrobor wrote:
1..  If you have multi stranded cable with thin copper wire it will create more resistance. That creates heat. For internal wall wires the thicker the strands the better.
2..  As you increase frequency this becomes more important. At UHF frequencies the signal does not go down the inside of the wire it goes down the skin.
 1..  The thin wires used in electric cords do have a higher resistance than the thicker house wiring wires, individually. However when you add the wires together to produce the same cross sectional area then the result is the same resistance in both cables. The same resistance will produce the same power loss for a given length of cable no matter how many wires go up to make the required cross section.
2..  Skin effect is only important in each wire in a cable if the wire is big enough for it to take effect. AT 60 Hz the skin depth is about 8.5 mm (200 mm2) so for any cable below 16 mm diameter we can discount skin effect at our mains frequency. If you don't insulate the strands of a multi stranded cable then the skin effect is taken over the whole diameter of the cable, that's why they developed Litz wire.
You should have quit some time ago whilst you were still ahead. You are becoming more stupid as you go along.
Permalink Closed
It is amazing how people attack what was meant to be a simple explanation of current flow in a conductor. Perhaps attack and try to kill is your best defense.
Electrons flowing through a conductor repulse other electrons. At DC or low frequency, electrons flow within the conductor and skin effect does not come into it. If you have 2 x 1mm conductors and a 2 mm solid conductor conducting current and you care to put an oscilloscope on both lines, you would find more white noise on the thinner wire. White noise is the impedance caused by electrons to other electrons flowing in the conductor. Try it gents. Rob.
Permalink Closed
Light circuit is generaly single core .. Keep in mind the cooling effect . In closed in insulation etc .. Better off not discussing as it gives info in stealth !!
Permalink Closed
Ohh my God  & he talks about simple explanations!!
I guess you are "trying confuseto explain  the electron theory of current flow
A typical example of a little knowledge but not much else!!
What an utter load of crapnonoyawnconfuse.
This forum is about Normal MAINS frequency  & DC ,of which you seem to know little!!
Very, very, few members have any interest in subjects dealing with high & ultra high frequencies.
Please tell us YOUR Qualifications ,
How did you earn the right to call yourself an Electronics" technician "?
Do you have any recognised certifIcates?
ps I spent a major part of my working life in the industrial electronics field .
Permalink Closed
Good grief are we down to " You show me yours and Ill show you mine". My pieces of paper sit, from memory in a box in the garage marked "archives not needed" . From memory there is 7 of the things. six from overseas and one from the land of the rainbow serpent. What do the mean to me?. It means I wasted 7 days of my life getting bits of paper and not much more. Bobbing heads! please is that it?. And no this forum covers everything. You may not wish to know about skin effect, but don't for one moment imagine others don't want to know. Put up An antenna today, what wire do you use?. Understand how the signal travels and you know without asking. I believe quite a number of people here have caravans and that information might just be handy. Rob.
Permalink Closed
Come on people,       I am sweating on Four Pages on this Post.  Better than watching Peyton Place
-- Edited by elliemike on Sunday 18th of September 2016 08:52:37 PM
Mike & Ellie
Permalink Closed
Thanks everyone for your input on this but I think I'll close this thread now. Just a reminder to please keep posts friendly and respectful.  Although we welcome differing points of view, we do not allow personal attacks.
«First  <  1 2 3 | Page of 3  sorted by
