Post Info TOPIC: Eden in nSW to Lakes Entrance, Vic
I am hoping to tow an 18' pop-top to Lakes Entrance in Vic, going down thru Bega / Eden, NSW.
My google search results suggest that much of the trip is through mountains.
Can anyone offer comment on how mountainous it might be, and is it suitable for a comfortable drive towing a van. My tug is a 4.8 litre Patrol.
Cheers to all. KB
We did it a couple of years ago in a 9m bus - first time we took it out in over 18 months. His 2nd time driving it - total. Roads are good, and inclines not too steep. We saw a lot of vans.
The Mobile Madhouse: me (Rosie), him (Troy), a kelpie, a kelpie-dingo, a husky & a rainbow lorikeet.
I did the trip some years ago with a 16' van and a 2.8 Patrol. No dramas at all, just took my time.
Never get so busy making a living
that you forget to make a life
I'm not familiar with the route that you are talking about but I'm certain that a 4.8L Patrol will have absolutely no trouble pulling an 18' pop top up any range.
My old 4.2 EFI Patrol has done the job with ease pulling a 22'6" caravan up most ranges in Australia over the last 20 years or so & still going well.
Just take it easy & use the gears going down the ranges.  I just get behind the semitrailers & wind it down just rarely using the breaks.
Fuel consumption is another story.
Hello keiron
As others have already said, it will be very doable with your rig
I went along the same route but in the opposite direction, at the end of 2013
Pulling a 17 foot pop-top, with an old Ford Falcon 6 cylinder 4 litre car
I had no problems, and as far as mountains go, I would probably give it at most 5 out of 10, compared to other steep hill I drove along, in other parts of my lap
Hope this info helps you out
If you stick to Hwy 1, no problem at all.
I actually did it early 2015 with unbeknown to me at the time, faulty van breaks so the Colorado was actually doing all the work. All got fixed at Uladulla NSW. I also had the wrong brake control fitted to the Collie. Now changed as well.
Just take your time and keep safe on the roads and out there.
Many thanks for those replies.
I will proceed with renewed confidence and faith.
Cheers, KB
KB,you will have no problems from Eden to Lakes Entrance.We go at least 4 times a yrs.to Eden from Bairnsdale towing a van.About 23kms. before Cann River is where you find it the windiest and steepest,you will be down to about 50 km.for about 6kms .But it is no problem.
-- Edited by Plain Truth on Thursday 1st of September 2016 07:30:18 PM
 From where? Are you coming down through Wollongong/Nowra or through Canberra? If you come down through Wollongong then you will be descending Mount Ousley. This will tax your brakes if you don't use steep hill descent techniques. If you come through Canberra you will come down Brown or Clyde mountain. Both of these definitely need steep hill descent techniques. I see you are from Sydney, the Clyde and the Brown Mountains have similar gradients to the Bells Line of Road or Mt Victoria Pass. When descending these you need to slow down and change down gears (auto or manual.) You should slow down and use a gear low enough so you don't have to use your brakes much
The roads I have mentioned are a full 2 lanes wide (wide enough to have edge lines painted on them.) They are used by semi-trailers so you should be able to use them. Just learn to drive them and you will be perfectly safe using them.
