Post Info TOPIC: Lithium so up and running
Permalink Closed
well my 400 amp lithium pack is up and running taken a wile but it's alive now.
gdyble
Permalink Closed
Waiting for wife to get up so I can do a load of washing thanks to the sun.
Can't seam to get a pic up
Dibs
gdyble
Permalink Closed
Hi Dibs
Holy Moses you going to do the washingbiggrinbiggrin
Good on you mate,Della will love for that
Maybe you have to do it now all the time
I bet she will get used to itbiggrinbiggrin
Cheers John
Permalink Closed
400 AMPS of lithium, WOW.......... tim the toolman would be impressed.....well done
Permalink Closed
Yea stoney gives me 700 od usable amps. Weighs 65 kgs pluses a bit more for the system but well worth it 800 watt solar going for a bit more so I can use the air con when I want . Gotta love being able to boil the jug use the microb wave or the air con and as above the washing machine .
Dibs
gdyble
Permalink Closed
Would love to have a 400 amp system that gave me 700 od usable amps.
Permalink Closed
Hi Dibs
I'm maybe not the brightest but I don't understand this
"gives me 700 od usable amps" ?????
How can you get 700 amps out of 400 amps LifePo4
Do you include your old batteries in that mate
Cheers John
Permalink Closed
I will explain it when I see ya m8. Hey were goin to I skip this week for a few days if ya want come down . Or were going to be at Burnett heads after that . We was gunna stay at Harvey bay but there ain't no free camps there hahahahah.
dibs
gdyble
Permalink Closed
Your working them Batteries Dibs.
All still OK by the sounds of it.
Remember you know your not allowed to use all that stuff but I forgot to tell you that so like me you will have to flounder on using them and enjoying life till we realise that we just cant do it.
Over 5 years for me and I still have not learnt so still doing it.
Best when it is stinking hot at a camp site and you announce you are going for a SCAN under the aircon for a few hours.
Has Della got all her 240v goodies yet.
Brian
Permalink Closed
Cruising Cruze wrote:
Hi Dibs
Cheers John
The terminology is not correct
It is a 400 AmpHr pack
But like any battery ,the available Instantaneous current  is many multiples of that  especially with Lis.
But I suspect even that is what not is meant !
I think what is meant that it would require 700Ahrs of La batteries to obtain the same Amphrs Output without damaging the LA batteriessmile
Permalink Closed
No i think what I ment is 400 amp lithium because it can be discharged to 20% dod against 400 amp gel with its discharge to 50% dos gives about the aqulivant of 700 ish amps . Am I right there Brian . Means I can stay out of the sun longer .
Yea Brian della finished the washing the other day came in with a smile saying she loves her new system . She's all for plugging it into the house at bunny now . It was putting in 10 amps wile running the washing machine . But I'm thinking of going the extra 300 on the roof .
Did you sort your problem out yet
Dibs
gdyble
Permalink Closed
How would Brian Know the Tech terms ,he will have to ask his mentorbiggrin??
Battery capacity is in AMPHRS , no matter the type !!
You have a lithium battery capacity of 400 AMPHRS & THAT is the very most that you can get out of them but leaving a safe margin of 20% really means 320AMPHRS
Now because you can regularly discharge them deeper than LAs, that is equivalent to 700 AMPHRS of capacity with LAs[because you will destroy LAs if you frequently discharge them lower than around 50%]that means you can only safely get 350 Ahrs out of them without seriously shortening their life
Peak currents , max CURRENT [AMPS ]they can put out is totally different thing to AMPhrs!!
-- Edited by oldtrack123 on Wednesday 21st of September 2016 09:17:53 PM
Permalink Closed
Lost me completely
the seconds keep on ticking away
Permalink Closed
See you got it in 1 old track but I don't know why you have to put people down like you did Brian . He has had his setup for 6 yrs and should know what I was talking about . Sorry I didn't put amp hrs but I think John knows what I was talking about a m8888888888888888 lmdo . It amazes me how people put posts up from the way people jump on each other . Maybe I should keep my stories to myself or should I just bugger of like a lot of other people have.
Dibs
gdyble
Permalink Closed
Dibs
Yes, Brian might have known ,but other readers???? no
John certainly had problems smile
Next thing we will hear is that you  only  need half the solar with LIsbiggrin
Permalink Closed
Hi Dibs
Cheers John
HE cannot get 700Ahrs out of 400Amphrs battery no matter what type biggrin
Permalink Closed
Lol it's a wonder you haven't startedpicking on my spelling or are you leaving that up to the spelling police . Instead of putting people down why don't people work together and explain things as it is . You seam to know more than every one else here so I will just sit on the side and watch you tell my story
 Ok so I probably did go of half ****ed . I was excited about my new setup as a few close friends on here know my or our story . I might have misled . So now I will try to explain what I ment . Iffffff you have 12 volt 100 AMP HR lifeo4 batterie and a 12 volt 100 AMP HR gel batterie side by side . because you can pull 80 AMPS out of a lithium batterie and only 50 AMPSout of a gel batterie it's a bit like having extra power . i think that's rite hahahahaha if it's not I will delete  the post but if someone out there thinks they know more than me or better than me they are welcome to help out not put s)8t on me or people who have helped me out .
i never even hinted I need less solar so why your smart remarks I cannot wonder why .
Dibs
-- Edited by mr glassies on Thursday 22nd of September 2016 07:32:43 AM
gdyble
Permalink Closed
Have they let you out from under the bridge again Peter, seems you have a tendency to attack rather than try to explain, but I guess that comes from your normal method of operation, if you don't actually know what your talking about then attack and spin B/S as hard as you can blow no
This 80% theory, you have that from actual hands on testing of Li batteries.... or just hands on something else?
T1 Terry
Permalink Closed
Oldtrack says
How would Brian Know the Tech terms ,he will have to ask his mentorbiggrin??"
I hope Cindy is reading this as the attack on my presumed knowledge from a person who has never met or know me but has continually attacked me on many forums because I will not advise him on the system I have, was not called for and I consider it defamatory and will investigate further.
I did not put anything in the post that was technical on purpose and never will I just made a comment between friends who know each other and know what they have.
Also to say that I must ask my mentor is an insult not only to me but to Terry who has pioneered the development of the batteries.
This person has no knowledge of my experience through my life and I consider it an insult the way he attacks myself and anyone else who does not prescribes to his views.
I left this forum before because of this person and a couple of his mates who were after the data that we have and it appears I will have to leave again as I don't see the need to put up with innuendos from people of the caliber of him.
Dibs has just had his system installed and understandably was excited but did not have to have the electric police jump on him.
If this forum wants no discussion on Lithium Batteries then so be it, but a decision from Cindy would be appreciated.
If I knew how to report the poster I would so if anyone else knows how it is done I would appreciate them doing it form me.
Permalink Closed
Maybe his name should be attack123 hahahah
Dibs
gdyble
Permalink Closed
T1 Terry
 How is  your looong inforced holiday from that other forum going ??
And of course  not the first time!! [by many ] is it .
Was it not due to your personal attacks ,on myself & many others?????
Virtually every post you got on, ended up being lockedno
By the way the 80% comes from Dibbs own post
[Quote]No i think what I ment is 400 amp lithium because it can be discharged to 20% dod against 400 amp gel with its discharge to 50% dos gives about the aqulivant of 700 ish amps . Am I right there Brian . Means I can stay out of the sun longer . [end quote]biggrin
-- Edited by oldtrack123 on Sunday 25th of September 2016 11:33:52 PM
Permalink Closed
Still a long way to go before you understand about lithium batteries Peter, best to stick to what you know, how to quote Australian Standards and the word "shall" appears to be a popular one.
How am I doing after the ban from the CF? I'm surprised by your concern Peter, I find it rather touching :lol: but maybe it's more a case of you loosing someone to fight with ;) I didn't like the change in admin direction over there, censorship to change a thread direction is not the job of Admin, now most of the good Admin have left over there it is deteriorating into a shadow of its former glory so I'm quite happy not being there really.
T1 Terry
Permalink Closed
Fair go guys .. Just look at what you've written here ? Like the rest of us are interesting in Kadsasian type posts . Get a life !!
Permalink Closed
I love the batteries terry thank you so much for everything you have done for us !nothing like having to not book a powered site and still do your washing and charge up all of your phones ect !we will cherish the time spent with you and margaret and look forward to catching up again ive read the comments above you can only laugh !gooooo t1 lithium yahoooò
glassies
Permalink Closed
Hi everyone,
Thanks for your input on this but I think I will close this now.  We welcome discussion on all topics (except religion and politics), however, we do not allow personal attacks or discussions about what may or may not have happened on other forums. Please keep comments focused on the topic rather than on the person who posted it. Thanks.
