Post Info TOPIC: Diesel Heater Installers
Hi Nomad Helpers,
 I have just bought myself a Diesel Heater , after a few coolish nights out there, and I would like to know
if somebody could recommend somebody to fit one of these for me. I live in the Tweed Gold Coast area.
I would be willing to travel to Brisbane or South to Ballina if they can recommend somebody that would
do it well. Hoping you can help.
Chucker....
chucker-if you are a little bit of a handy man you can do yourself.i fitted mine -works very well. the vicar
If you do feel up to it, then a local handy man should be able to do it. Hardest part is cutting the large hole.
Who ever does it, just read thru the instructions, fit it all together outside the van, just to ensure you don't have parts missing and to also see how it fits together.
Decide where it is going to be located, check there is no steel or pipes where the hole is to be cut, and also where the ducting/outlets are going. Best to have the inlet away from the hot air outlet. Also where are you going to mount the diesel tank.
Glen
I've thought about DIY, but , it makes me a little nervous.
Dunno. Fuel and Electrics frighten me a little .
Hope for help or maybe , nah don't think I'm game.
TIA Chucker.
hi there BATTERY WISE AT SUNSHINE COAST DO SERVICE THEM  PH 07 54376799 THEY WOULD KNOW WHO FIT THEM OR RING DOMETIC AS THEY WILL GIVE YOU AN INSTALLER regards mark and kerry breeds
Recreational Appliance Services. Chris, 0419929030...1/10 Warrell St W Ipswich Q. Check the filter on the inlet before you do anything.
Thanks... I'll give them both a call to see who can help me.
Nomad help is never to far away.
Thanks and Regards Chucker.
What a shame I didn't log on earlier,  we have just left the coast &  would have been happy to help you fit it.  I just did mine a few weeks ago &  this was my 2nd one.
 Neil
Neil & Lynne
Pinjarra
Western Australia
Iv said it before and I will say it every time I see a post about diesel heaters . When there installed make sure the exhaust and inlet pipes are more than 1500 mm from the gases regulator .( it's the law)
Dibs
gdyble
