Post Info TOPIC: 240 power
bax
240 power
Lost 240 power , have read that it maybe the safety switch failing, where would I locate this switch in a 2015 Starcraft outback?
The switch should be inside one of the cupboards close to the inlet connector. Locate where you plug the power cord into and look around on the inside close to that.
bax
What would it look like; is it like a fuse switch?
Similar to an rcd you get at home in your elec box outside.
Will have on/off clearly marked on front.
Gday Bax and welcome to the forum.
As has been stated it is near the inlet, we have a 2013 starcraft and its in the overhead cupboard inside the van closest to plug (outside).
Its disappointing the dealer didnt show you all these devices when the van was delivered.
bax
Thanks for all your help guys, found it as just advised in overhead cupboard, behind the insect spray, all good now Cheers Bax
bax
Just had my circuit breaker replaced because the ants got inside and stuffed it, cost $50 and $45 for call out
Tug - Fuso Canter 515 and Living Edge van
The Wandering OAP
