Post Info TOPIC: change ATM
change ATM
confuseconfuseconfuse Just foned Crusader caravans about changing the atm on my caravan as it is only 2820kg  took it over the local weigh bridge ,empty water tank, no food or clothes ,It came to 2715kg .As you can tell not much extra for the essentials .So i had changed up to atm 3200kg ,the same as the axle group rating .It was as easy as a fone call ,i do not know why they did not do it from the factory . What are your thoughts .JOHN.biggrinbiggrinbiggrin
  Atherton tableland Nth Queensland. Currently have a Crusader Manhatton ,But in april 2017 will be trading it in on a Retreat Brampton.
You will also need to advise Qld Transport so they can alter their records.
Bill B
biggrinbiggrinThanks Bill ,Will do.
this has been well discussed in the past with various ideas put forward as to why the manufacturers do what they do with allowing little weight variance when it rolls off the sales yard.
We did the same thing with our 'van - no arguments and we got a new VIN plate the same week. But in WA, you have to get it pit inspected and road tested, and a weight docket. Costs around $280.00. You cant take the old VIN plate off - they screw the new plate above it. The requirements vary from State to State, so it pays to contact your state Transport Dept
Cheers Bruce
We just had our vans atm upgraded to 2750 Which the chassis was rated at manufacturers wond upgrade had engineer to sigh off on it whent from tars 1721 2121 atm to 2750 with ball weight 275kg was a long project but worth it van is legal now
Testing
