Post Info TOPIC: roadside assist
roadside assist
hi there has any one found an insurance for motorhomes 4.2 tonnes for roadside assist . including towing etc . no one i have found incl racq or motoring 24/7 etc seem to be interested.  its a worry as we have an fiat avan and dealers ere few and far between thanks for any info mark and kerry
Welcome to the gang Mark and Kerry, enjoy here and out in the playground.
Having a caravan not a motorhome I can't help with you question so will sit this one out but wish you all best in finding what you ask about.
Keep Safe on the roads.
We are insured with Ken Tame through Cmca and our policy includes towing to the nearest repairer very good to deal with you just have to join cmca
Dragonfly1
C Geyer
Hi Mark and Kerry
I would also agree with dragonfly1. Ken Tame insurance is definitely worth a look. To join the CMCA is $60 odd dollars per year so no big deal PLUS it gives you some added bonuses so well worth joining even without the insurance. CMCA has 60 000 members so Ken Tame Insurance has to be very careful in its level of service as it relies on the members.
I don't have a motor home but have a Yank ute and a big van with an ATM of 4.2T so our rig is WORSE than a motor home and we get the cover. We are 16.2m in total length.
Neil
Don't look back - you only get a sore neck!
JCT
Suggest you take a look at the following on www.avidarvclub.com.au
The para below is an extract from that site in relation to the Avida roadside assist.
It covers the Avida/ Winnebago Longreach which is a big vehicle.
You do not need to own an Avida to join the Roadside Assistance Program. This program is one of the few without weight or height restrictions and has been specifically developed for the RV lifestyle.
From minor roadside repairs to security system advice and vehicle recovery following breakdown, our roadside assistance scheme has it covered. Checking electrical problems, jumpstarting flat batteries, tyre change and replacement of lost keys are just some of the many areas where we can help.
To find out more download the brochure or to join call 1800 CLUB RV (1800 2582 78).
I have my Birdsville covered with them and whilst I have been fortunate and never had need to use them I have never heard of any complaints. The Avida club forum references to the cover is complimentary from those who have had need to call on their services.
Nothing to loose by taking a look and making a phone call to clarify any query you may have.
Good luck and stay safe in your travels
Colin
Hi and welcome
As already said we are also with Ken Tame for our m/h. We find them ok. There phone no is 03 melb 98535555 or info@kentame.com.au al the best cheers
thank you very much for your info mark and kerry
many thanks for your info will check out mark and kerry
many thanks will investigate mark and kerry
have done thank you very much from mark and kerry
RACWA ultimate cover will cover towing a 9 tonne motor home. Sadly tried it out. A drop deck semi was used and covered for 450klm towing by RACWA. Neil
thank you for the help i rang avida and found them very helpful all looks good ta from mark and  kerry
NRMA have a heavy vehicle policy available....around $325 per yr.
thank so much i was directed to avida and they coudnt be more helpful so all signed up there packeage is very good for m/homes over 3.5 tonne regards mark and kerry
well done....al the best.
