Post Info TOPIC: map of australia
map of australia
I noticed at the recent qld caravan show one of the caravan brands (cant remember which one ) had a decal style map of Australia inserted into the outside table backing
can any one tell me where I may get one
brian
Not sure if this is what your after.
www.coolartvinyl.com.au/australian-p-249.html
www.thewallstickercompany.com.au/search.php
BaupleNut
yes that is similar
but am open to more options if available
brian
Or this.
www.homemaps.com.au/sticker-map.html
BaupleNut
I have seen that one which is a possibility
but the one I saw was more detailed, it had place names on it
brian
find a map with the detail you require, take it to a signwriter with a large format printer. THEY WILL SCAN THE MAP PICTURE YOU HAVE AND TURN IT INTO A FORMAT/FILE TYPE THEY CAN WORK WITH AND PRINT AND CUT TO A SIZE YOU REQUIRE UPTO ABOUT 1200MM WIDE. SORRY ABOUT the caps
blaze
I just got a Hema map of the required size (their office is just down the road from me) & had it laminated.
One in a frame on a blank wall in the van, marked up with most major tours & another above my study desk.
thanks blaze and cupie both good suggestions
brian
Go to any office works they will scan and laminate any map
Dizzy10
So do you want a detailed map? A vinyl stick on map? A laminated map? If you want something to record your journey, then a laminated map simply stuck to the wall of the van with blue tack, no weight to worry about no frame to break when it falls and able to mark your route.
BaupleNut
I thought the map behind the outside fold down table looked good
I could put a adheasive decal there and put our travels on it
that why I would like a map with some details on it
when I saw them at the c/van show they appealed to me but the salesman wanted to sell vans not maps (understandable)
and I posed the question here in case some one knew where they came from
brian
