Post Info TOPIC: Fridge alarm
Fridge alarm
Hi Guys
I have a 2 door 3 way fridge in my new van ,Dometic I think.
When on gas the needle is in the green but when the lpg runs out the needle indicates off but NO audible alarm.
On our previous fridge the orange ignition switch would keep clicking If out of gas.
My question is has anyone rigged an audio alarm on the new style of fridge.
ps. The fridge works excellent , even with 40degree temps for days on end it can make ice cubes in 6 hours  .
Regards Peter
Greet everyone as a friend, its up to them to prove you wrong.
Sorry Peter I don't have an alarm on my 2 door Thetford fridge but I agree that to have one would be handy. Another thing that also would be handy is a guage or something to let you know the fridge is actually on while using 240v or 12v.
I go on what I call "Fridge watch" around day ten if on gas for 24/7. I get approx 13 days out of a 9kg gas bottle.
I will keep an eye on this thread as is a good topic Peter.
Our previous van 2013 model, had a Dometic RMD 8551 fridge.  It had an alarm that sounded if...Gas ran out, or 12v or 240v disconnected while fridge was still switched on.
It also sounded if the door was left open too long (about 2 minutes from memory).
Cheers Neil
Neil & Lynne
Pinjarra
Western Australia
Hi Pete .I have to say I agree with Doug,that is to say one has to stop relying on machines and alarms every now and then.You have to start gauging your various quantities for their outputs.Bugger alarms ! I mean if I am driving for 4 hrs at 100 ks I dont have to look at the fuel gauge to know that I am getting real close to looking for a servo ,or after 3 days of free camping the water level is getting dodgy.These are things that will or should become automatic .That way you will never be left in a dire situation.Alarms are a great benefit ,however they will never !....replace common sense .Cheers
 Alarms are handy if you have a lapse in common sense as I did a few weeks ago putting some unleaded in my diesel!!!!cry No alarm to save me though.no
Aussie Paul. smile
Thanks for the input guys, after asking the question I started searching and found a digital thermometer with alarm for $25 at jcar, I know vigilance is my best option but if I last check the fridge at8pm then again at 8am to find a puddle in the bottom it has a dramatic influence on my lovely wife's normally placid nature.
 I don't think anyone with half a brain totally relies on alarms for these things.
I too know for instance that I get 10 - 12 days from a gas bottle when free camping but - unlike watching the car fuel gauge I am not going to re-fill a gas bottle because it is getting 'close' to empty.  I want an alarm to tell me the moment it runs out so I can switch bottles. Cheers
Neil & Lynne
Pinjarra
Western Australia
Leather techs we have an automatic change over gas regulator so only need to check the regulator occasionally to see if one gas bottle is empty. When it is you switch the valve to point to full bottle then the empty can be removed for refilling as the pigtail is then isolated so no gas leaks. Got the regulator from caravans plus.
Alan
Alan
 Thanks Alan, I hadn't heard of that.  Does it tell you in some way that is has switched bottles?
Neil.
Neil & Lynne
Pinjarra
Western Australia
Delta 18 the regulator has an indicator window and a selectable lever that points to the bottle being used, if that bottle still has gas the indicator window is green. If that bottle is empty and supply is now from the other bottle the window is red. Have a look at caravans plus website. the brand was CEM.
Alan
I put a thermostat on the stack of the gas burner and wired in a audible alarm with a switch to turn the alarm off.
I do not have the details of the parts I got from Jaycar because I am traveling. My old fridge, when the gas ran out you could hear the ignition clicking to reignite it.
