Post Info TOPIC: 2008 XLT Ford Ranger dual cab diesel
G'day Nomads,
I am wondering if anyone out there has some first hand knowledge on the pros and cons of this vehicle ?
Any info would be appreciated
Nobby
Hi Nobby. Don't have 1st hand knowledge, but went to the search function at the top of this page and entered "Ford Ranger". Theres about 4 posts on various model Rangers, including one on the one you are asking about. Maybe be helpful to you...........
Cheers Bruce
I have a 2010 Ranger and am very impressed with it, I tow in 4th gear and have never had a problem, got 61000 ks up now and going strong.
Dave
It's all up to the servicing . Sure it's easy to hear negative things about automotive things . But most only care about maintenance when things stop working ! Then omg better check oil , check this and that . Take to mechanic ., too late . Like our health . With mechanical things it can't be healed or undone .
Thanks Bruce I will follow it up
Nobby
Thanks Dave, much appreciated.
Regards Nobby
Very Wise Guru, looking forward to the All Blacks V Wallabies tests this year.
regards
Nobby
Nobby - I can help you out with the Test - the Wallabies will be thrashed as usual !
Sorry to give you such bad news, but us Kiwis are good at a few things (and no sheep jokes.....there are more sheep per head of population in Aust now than in NZ)
Cheers Bruce
G-day Nobby. We have a xl 2008 ranger . No problems just turned over 100000 kms. Last 10000 towing van,averaging 16.5 lts to 100 clicks.
hi
Pk single cab 3.0lt `07
some items from new some at 40,000kms some at 60,000kms   Currently 80,000kms
Things I have experienced
gears going very notchy
first clutch you will probably need the aftermarket flywheel kit
Centre splines if u tow often will have movement
Power steering box has noise occasionally whining
Air con is rubbish in high humidity
Occasionally u may have water entry into cabin in the morning after heavy overnight rain
Starting roughly dealer wont pick it but head gasket or ECU
injectors replaced due to bad fuel economy
faulty new injector
bonnet catch needs Ford recall so it does not fly off at speed
Rear diff plug filler hole to low there is a recall at Ford Its a sticker ha ha ha ha ha put diff on angle and then fill
inlet manifold full of sludge and carbon
sensors in inlet manifold get covered in sludge
If u are a larger person it encourages it but not the only cause . The seat wires will poke thru the seat mainly on the sides of both base and back support
All of the above is common to most Ranger/ Bt50 owners as well
.................Items that are happening to many early Ranger /Bt50 owners................
Blown EGR cooler Causing overheating and destroys head
Blown Head Gasket
Exploding /Blown rear diff no oil most likely due to diff plug height
ECU
Recall Factory cruise control was a major issue for Ford .They pulled it production
Auto transmission not changing properly Ford does have issues with many of there autos in other cars as well . surprise surprise
4wd 5th gear rectification kit from FORD
There are a number of reports and proof by one my friends blown engine /conrod thru side of block. Mazda would not pay 3mths out of warranty .
Hope this helps
Swamp                ps our next car was a Hilux no suprises
-- Edited by swamp on Saturday 4th of June 2016 09:54:43 PM
No vehicle is free of issues . A work Hilux has recently spun the outer ring off the harmonic balancer. Pushing timing cover onto valve train drive . Disabiling cam rotation . Result ? Smashed and broken cam . Whole new engine .. The transmissions in them are not as tuff as the older Toyota's . Or they havnt up graded trans with newer engines torque / power levels ., EGR is common issue with new diesels due to new emissions . Often these things are missed in servicing ?
We bought a run-out PK model in January 2011 just before the 3.2 was released. We found it a great vehicle until it was struck by lightning in our driveway in January 2015. It had 70,000+ kms on the speedo, 50,000 kms of those would have been clocked up towing our 17ft caravan which it did with one leg in the air. We'd still have it now if it wasn't for Huey! It went like clockwork for 4 years. Fuel consumption was good while towing. Ford Dealer service was crap, we found another diesel mechanic after the first year of ownership.
Cheers Keith
Our land abounds in Nature's gifts, of beauty rich & rare. We'll be out there enjoying it somewhere, camped by ourselves much of the time.
