Post Info TOPIC: 2003 coaster floor dimensions
hi all I'm new here,
can anybody steer me in the right direction to find a Floorplan for a 2003 and newer coaster.
im trying to work out a Floorplan to suit the family.
gus
Welcome to the gang Gus, enjoy here and out in the playground.
I'm not sure if you are asking for dimensions of the "2003 and new coaster" or just after a few ideas for a floor plan, i.e. where to put beds, fridge, shower, sink etc etc.
If dimensions, maybe contact Toyota if you haven't already or maybe ask Mr Google.
If ideas, maybe have a peak at the for sale sections of forums, web sites etc for internal pics, might give you some ideas.
Most people have the bed going across the back and maybe a bunk down one side for kids, as you say "family".
Just a couple of thoughts.
Hello Gusthewonderslug
As Dougwe has already said
Welcome to the forum, and enjoy your stay here
I am sure that the members who had/have a Coaster Bus motorhome will come along to help you out
I was looking very hard at second hand Coasters, prior to buying what I have now
Apart from what Dougwe has already described, with bed layout, and searching the Internet, I can add no more, except to say:-
I did not actually see what I would describe as a standard floor plan for a Coaster Bus motorhome, as they were all slightly different, with their interior design, and fittings
Hope this info helps you a little bit
Hi Gus,
Whilst I've never converted a Coaster, I have converted several Buses and Coaches many many moons ago. With any conversion there's no such thing as a standard layout. Your conversion should be custom to include all the things needed to fit your purpose.  Best advice I can give you is grab a pen & pad and first list all the things you want included and then start making some scetches of layouts to include all those things needed.
When you have a couple of layouts in mind, then transform your ideas onto some graph paper and rework your layout/s into a scale drawing to see if it will work.  When it works on paper then start your build but be prepared to make changes as you go. A general rule is that the fitout should weight less than all the seats removed from the bus.
Hope this helps, Steve.
