Post Info TOPIC: 12v and solar help needed in the Darwin region
Hi we have two problems we cannot fix on the road the first is we are only generating about half the expected solar and suspect we need to run a separate line for the second panel we have a 40amp bcdc and it should be big enough for 2 200w panels. The other problem is that when we travel we blow the main 12v fuse we hxave tried isolating things but no luck any help with a recomendation would be appreciated Trevor and Pamela
Trevor & Pamela
There's a Solar sub forum in the Techies forum, you might find some answers there, its worth a look.
Good luck
Cheers gemmybob
Tellem-Buggerem
If you dont know what it is, "lick it".
If you still dont know what it is,
Try not to lick it again.
Where are you in Darwin?? Im out at Humpty Doo & might be able to help.
currently at Adelaide river and plan to spend some time in Litchfield then on to Darwin I will pm you if thats ok
Trevor & Pamela
Sounds like a plan.
