Rocky the problem is your are a very intelligent person and I tell you that for free. You need to be a simple person to read simple instructions. Maybe if you got a DISstruction book from Emanual.
Sorry mate.
None of that pic makes any sense to me at all maybe if you tell us what it is for perhaps.
DOUGChief One Feather (Losing feathers with age)
DEN....... 2014 "Chief" Arrow CV (with some changes)
In my day that diagram would be handed to an apprentice to go and get one at the local hardware store, and be told to be sure the right nuts were included.
I had a thought but it got run over as it crossed my mind.
Rocky, my main man it is fairly obvious mate, the convobulator needs to be inserted in the fuffoo valve sideways giving a maximum clearance of 0000.1 of a clacker. This will allow a degree of movement in the schlacken tappet which will enable it to be screwed more securely.
Should you require any further advice do not hesitate to ask the Phantom.
-- Edited by Magnarc on Tuesday 16th of February 2016 12:06:29 PM
"Some days you are the Dog and some days you are the tree."
Geez, that had me going for a bit - just got my glasses back from an optician today after the frame was repaired (after I sat on them last week ) and wondered if they did something to the lenses as well. Then I noticed who the OP was ... 'nuf said!!
My eyes are still pointing in different directions.
Joe
-- Edited by Joe50 on Wednesday 17th of February 2016 12:17:04 AM
Really Rocky, thought you would be able to assemble this without needing a swamp throttle eliminator. Suggest you use simple ocker bolts and a non rusty tool to fix this in seconds! RambleGambol
