Post Info TOPIC: napisan clones
napisan clones
I am wondering if you were to premix an amount  of any of the napisan clones in water and then let it sit in plastic bottles till needed, would it tend too lose any of it's effectiveness over some time?
Cheers John
It works by releasing oxygen as it dissolves.
I add it to the toilet dry and let the liquid in the toilet dissolve it slowly.
I use the home brand one - apparently the woolworths one is best suited for the toilet cassette. Something about one of the additives which the home brands don't have in them!
Glen
Glen
Sodium Percarbonate is the chemical, check the label the higher the content the better.
Nope, it's not a Furphy.biggrin
Santa.
JCT
John,
we tried premixing once.
Filled a plastic bottle with napisan and water and put half into the empty toilet, all good And we had some premixed for top ups if needed.
We then travelled to our next destination some 4 hours away and when we went into the bathroom the remaining premix was all over the walks and floor. The plastic bottle has exploded, fortunately no ome was in the bathroom at the time.
Needeless to say we will never again leave any mixed napisan outside of the toilet.
Colin
Colin, could have been worse - could have been the toilet that exploded, LOL.
Cheers John.
We have been using the cheap Napisan products for 13yrs now with good results but found only one of them has the higher concern of Sodium Percarbonate being the Woolies Brand and also $2 extra now. I have since purchased a kilo of 100% pure Sodium Percarbonate from a Home Brew shop when passing through Adelaide. I only use a teaspoon of this product as compared to a capful of the cheap Napisan and find it works well at this concern. The price was $14/kilo.
We also have a 2 litre bottle of the Sodium Percarbonate mixed with water for toilet flushing use with a hole in the lid but always make sure it is securely placed. When mixed the combination of the Napisan and water causes a reaction which can cause excessive pressure buildup. So not a good idea to totally seal the container. Using this for flushing stops excess water use which fills the Cassette quicker.
Cheers Kev.
Coles brand has 34% sodium percarbonate. Woolies have dropped theirs to 28%.
The Happy Helper
Got to look hard for the sodium per carbonate content, usually in tiny letters, somewhere on the container. As sands mere says, Coles brand has higher pic content.
jules
(Ben, aged 10)
 Reject Shop version has 34% as well.
Neil & Lynne
Pinjarra
Western Australia
MY23.5 Ford Wildtrak V6 Dual Cab / 12/2025 Silverline 22.68.5
The Happy Helper
Neil - that's the one I use - Supreme - works really well, and cheap - in WA you can get it at Red Dot shops as well.
jules
(Ben, aged 10)
We have a small Portypotti , haven't used it yet , still new in the box , it came with 2 small bottles of chemical , should l not bother and just use nappisan
What's the go with nappisan , do you just add some to the waste tank after use and how much .
meetoo wrote:
Thanks all for the replies.  Anyone got any more insight to the original question? :)
"I am wondering if you were to premix an amount  of any of the napisan clones in water and then let it sit in plastic bottles till needed, would it tend too lose any of it's effectiveness over some time?"
Thanks
Cheers John
Thanks
Cheers John
 You were advised that it releases oxygen on contact with water thus begins 'wearing out' immediately.  This also can cause the bottle to explode!  What more do you need to know to not do it?
It really is not difficult to drop a teaspoon full at every #2.  I wrap it in a sheet of loo paper too make a 'bomb' of it.  No chance of the granules getting into the seal.
Cheers Neil
Neil & Lynne
Pinjarra
Western Australia
@ John, DO NOT store premixed "Soaker" as alluded to here it will become active as soon as mixed with water not only will it start to lose it's effectiveness, it will explode if kept in a plastic bottle. (from first hand experience).
@ Jacko; use the supplied chemicals , you've paid for it so use it, or keep until you run out of "soaker" in remote area or expensive shopping area.
I also now put 4 teaspoons of dry powder into cassette after emptying - first No.1 will activate.
Sometimes I shakes me head.....
Someone wants to start a thread about van modifications, and is told it should be in the hints and tips, instead of in the most logical sub-forum...
Now we have a thread about poo container additives in the Techies instead of Hints & #%^%$@% Tips
Glad I re asked. I have a much better understanding now of how it works. (It finally soaked in, lol)
Thanks all.
Cheers, John
For them that are inclined to make their own beer, Napisan or it's clones, is a good sterilising agent to do your equipment and bottles.
Just dissolve 40g sodium percarbonate in 1 litre of water and tip into your fermenting container. Top up with water and dump all your utensils into the container (airlock, stirrers, bottle filling gizmo, etc. Do the same to sterilise your bottles. Saves spending heaps on packaged sterilisers from the manufacturers of the ingredients.
It is obvious that everything in the world relates back to beer.
The Phantom
Don't use it.
Some of the toilet chemicals still contain stuff that is extremely bad for the environment and this has caused many people to ban the emptying of portable toilets into septic systems.
If you use them it can be very difficult to get rid from the inside of the toilet and it can upset the effective use of the sodium percarbonate.
Sodium percarbonate is no danger to septic systems or the general environment. It breaks down to harmless stuff very quickly.
Adding the sodium percarbonate dry is fine. A small teaspoon per day is probably excessive. Using more does not do a better job.
Peter_n_Margaret wrote:
Don't use it.
 Particularly if it is blue or brown liquid. The green Thetford liquid may be OK environmentally but it may give the problems in removal of traces as Peter alluded to.
Ok thanks , l will get some Nappisan or a clone .
Don't believe every ''handy hint'' you read on a RV Forum. We were told to put 200ml of Milton baby bottle sterilizer in our water tank then fill it with water & take the van for a 10km drive to mix it around. Drain the tank & then fill with drinking water. The water tank has now been cleared of any algal growth. Trouble is for the next 10 tank refills our drinking water tasted like cats piss. Never again. We use the Thetford chemicals for the receiver tank of our toilet & plain water for flushing , they work perfectly well. If you can't afford them you should be still working.
-- Edited by Desert Dweller on Wednesday 20th of January 2016 06:40:27 AM
Cheers Desert Dweller.
Our land abounds in Natures gifts. Of beauty rich and rare.
 lol DD , cost hasn't even been mentioned
Most Napisan users do it to save a quid. We tried using it for a while but went back to the ''real stuff''.
We use sodium percarbonate because it works better and it is safe for the environment.
It also happens to be cheaper and you can get it almost anywhere.
It's just that l have seen countless post about nappisan , because we didn't have a chemical dunny until now , l hadn't taken much notice until now
I thought nappisan must of been better , l don't know the cost of either product .
 We use sodium percarbonate because it the best and most environmental chemical at a reasonable price. If you wish to use commercial chemicals made for the potties you can purchase the ''real stuff'' in tablet form - Odour-B-Gone enviro friendly, Waste Cassette Tablets - at $24.30 for 450 - 500 gm. I will stick to using the same chemical in powdered form and not pay someone to compress it into tablets.
When I look at this page is see that a large percentage of the "real stuff" is not very environmentally friendly. Some of the green stuff offered does not have the condemned nasties in them but the chemical waste action is highly suspected of producing them.
By the eway what is the "real" stuff that you use?
-- Edited by PeterD on Wednesday 20th of January 2016 10:28:03 PM
We use Peterg green marine products and have found it to be good. It's around $20 for a litre bottle that lasts for 5 uses. You can buy larger bottles that make it more economical.
-- Edited by JeffRae on Friday 22nd of January 2016 10:09:20 PM
 This stuff? Peter G's Toilchem Green
I think I'll stick with the sodium percarbonate...
Yes, that stuff. Does a great job !
