Post Info TOPIC: INVERTER QUESTION
RE: INVERTER QUESTION
wasn_me wrote:
Thanks Peter, I have never heard of a green GPO. I thought the way it was being discussed here it may have been a GPO without a earth socket, so you could only use internally earthed appliances. Cheers Pete
Hi Waz
Here is link to a typical onebiggrin
https://welshpool.mm.mmem.com.au/socket-outlets/cli2015gr.html
The reason I mentioned a "green" GPO was to make sure it would be recognised as a different circuit and supply. In reality I truly believe the inverter should be a totally separated system from the caravan mains sub circuit, if there is a need for RCD and RVD protection so be it, however as long as safety measures are adopted during operation I would be inclined to think AOK.
Once again I admit my lack of full knowledge regarding inverters and their "normal" parameters in use.
From a practical viewpoint I have never had an issue, as I said I have a class 2 electric blanket and the chargers are all class 2.
Hi Phil
It is generally considered quite safe from shocks to earth IF you only use class2 Devices
By the way I do hope that green GPO has double pole switching!
oldtrack123 wrote:
Hi Phil
 I only use the outlets on the inverter, keeps me honest that way. smileHope you are well mate.
-- Edited by Phil C on Friday 30th of October 2015 05:57:17 AM
