Post Info TOPIC: Cabin Bright LED
Cabin Bright LED
 How good is this
Have a look at this led lights they use bugger all power for 700+ lumens
Is any one of us using this one's??
http://www.cabinbright.com/24m-5730-high-output-modular-light-boards/
Cheers John
Got two in my tow tug.
1 in cargo area and the other above seating area.
Heaps bright and got them off fleabay both for $4.95 ex Hong Kong delivered.
Same as in the linked photo.
Vince
Cheers from Vince
VK2FBUZ
I used these Jayco style 48 led units for under $10 from Ebay.....
http://www.ebay.com.au/itm/48-LED-JAYCO-LED-T10-INTERIOR-EXTERIOR-WEDGE-LIGHT-BULB-rv-leds-caravan-4x4-/261264962838?hash=item3cd49af516:m:mK5-6nik-I-EvWI5-VHf8oA
I might just get one of each to try as flasher lights for my van.
The ones that I made up from lengths of those coils of sticky backed LED strips are failing.  'Dry joints' on the soldered connections the problem.
 My Advice..... Don't!.  Indicator, Brake & Tail Lights should be ADR approved to avoid possible insurance issues in the event of an accident. The panel lights suggested by others below would be best used for internal lights or possibly awning lights.
Also the power/lumen ratings suggested by cabinbright are exagerated, Lumen for 5730/5630 24SMD's would be around 500 not the 750 claimed and power .15 amps??? on a 12v system these would be around 7.2 Watts not the 1.8watts claimed.
 My calculator in Windows 7 says 12 x 0.15 = 1.8
 Mine said that too!.
Some flasher units rely on the big current drawn from a conventional lamp to flash. The current drawn by a LED won't allow the flasher to operate and the LED stays on constantly. Two options. Get a new flasher can that handles LEDs or add ballast (Resistor) so the can still thinks there is still a conventional bulb. Been thru this trying to fit LEDs to motorbikes.
2015 Ranger XLT - 2014 Jurgens Sungazer
I'm not familiar with LED lighting as a user, so I'm relying on Wikipedia:
https://en.wikipedia.org/wiki/SMD_LED_Module
The above article suggests that the typical power rating for a 5730 SMD LED is 0.5W, and the efficacy ranges from 90 to 110 lumens per watt. Therefore 24 such LEDs should consume 12W of power and their output should be of the order of 1200 lumens.
The 5730-24 cabinbright LEDs are rated at 0.15A, 10-30V AC/DC, 750+ lumens. That in itself is ambiguous. If we assume this to mean that the rating is 0.15A at 30V, then the power consumption is 4.5W. At 100 lumens/watt, we would expect that the output should be 450 lumens.
Some 5630/5730 SMD LED's have a built-in Driver to regulate the input voltage to a constant output voltage. I would assume the 10-30V AC/DC indicated by CabinBright is the input voltage range, that said the electronics to do this are a bit bulky and not visible on the panel in the pics, they don't show the extra electronics needed and if they existed then the panel should appear a lot thicker than the ones pictured.
In my own testing of 24 SMD Panels using 5630/5730 type LED's on 12 volt systems show a power usage of 7.2 Watts and 500 Lumen Output and my experience with these LED panels is that most sellers (not all) under rate them on the actual power usage and over rate them on Lumen output.  In order to abide by the rules of this forum I can't really elaborate any more than that.
CabinBright's specs are obviously nonsense.
Clearly, if the panel accommodates an input voltage range of 10-30V AC/DC, then it MUST incorporate a rectifier and a regulator. Moreover, the regulator must be a switchmode type, otherwise it would be massively inefficient. Also, assuming that AC operation requires a unity power factor, then the electronics must incorporate PFC circuitry.
Then there is the question of how the LEDs are arranged. Does the panel consist of a single string of 24 LEDs in series, or 2 strings of 12 LEDs in parallel, 3 strings of 8, 4 of 6, 6 of 4, or 8 strings of 3?
Assuming that the typical voltage drop of a LED is 3V+, then, in order to accommodate an input voltage of 10V, either there are 8 strings of 3 LEDs powered from a step-down buck regulator, or the regulator must be a boost converter.
I wonder if the 0.15A current rating actually reflects the current drawn by each LED. That would mean that the power dissipation per LED is around 0.45W (= 3V x 0.15A).
A quick search turned up the following datasheets:
BL-LS5730A1S1UWC-0.5W:
http://www.betlux.com/product/SMD_LED/BL-LS5730A1S1.PDF
ultrawhite
5.7mm x 3.0mm
3.5V at 150mA
3.1V (typ), 4.0V(max)
35 - 55 lumens
BX-5730L:
http://www.yujiintl.com/files/high-cri-led-datasheets/BX5730L-YUJI.pdf
5.7mm x 3.0mm
3.0V - 3.4V at 150mA
40 - 49 lumens
ARL-5730D21W-S:
http://www.dimitra.by/files/datasheets/arl-5730d21w-s-0.5w.pdf
white
5.7mm x 3.0mm
3.0V - 4.0V at 150mA
500mW
30 - 35 lumens at 150mA
-- Edited by dorian on Saturday 24th of October 2015 09:31:01 AM
 The regulators that a lot of these units use is a simple series pass switch mode PWM type. If you use a good very fast switching transistor in the regulator they don't generate much heat. They are so small you probably would not recognise them with a casual glance.
I expect that these arrays would require boost converters.
                                                             boosted
                           inductor                 D        voltage
                             ___
                +----+-----+-UUU---------------+---->|---+------+
                |    |    .--------.           |         |      V ->
 AC/DC .-----.  |   +| C  |        |   R       |         |+     -
      -|~   +|--+   ---   |  PWM   |  ___      |        ===     |
      -|~   -|--+   ---   | boost  |-|___|--||-+        ---     |
       '-----'  |    |    |  reg   |        ||<- Q       |      V ->
         BR     +----+    '--------'        ||-+         |      -
                     |     |  |current         |         |      |  LED
                    ===    |  |sense           |         |        string
                    GND    |  |                |         |      |
                          === |               GND       GND     |
                          GND |                                 V ->
                                                         150mA | | |
                                                               | | V
                                                          Rled '-'
                                                               GND
