Post Info TOPIC: Diesel Heater Fuel Tank
Has anyone experienced any problems with the fuel tank in the picture?  ie: light weight construction, leaks, poor seal on cap. Your feedback greatly appreciated.thumb-500x500.JPG
I would avoid steel tanks due to corrosion.
Try this guy in Turkey. He has free delivery to Australia and provides excellent service.. dieselheaters4u.com/index.html He has a UK Ebay shop.
(We met him in Turkey when we visited in 2013).
Thank you Peter for the heads up, I will check out the web site you have provided. Cheers.
Thought of outboard motor fuel tank ? pages.ebay.com/link/
Thanks for the suggestion, have thought of using one, but have insufficient room to install one.
My old motorhome had tank Mounted under floor with filler ..
Thanks again Guru, will keep in mind & have a look at what space I have under the caravan.
I have one of these tanks fitted in the front boot of our van and cannot fault it, I mounted it upright and can fill it from a bowser if needed, but mostly fill from a 5 litre can.
Dave
image.jpgCheck here for fuel cells .. You don't require the foam filled ...
http://www.ebay.com.au/sch/i.html?_odkw=solar+fan&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR11.TRC1.A0.H0.Xfuel+cell.TRS0&_nkw=fuel+cell&_sacat=0
I used an outboard 2 stroke oil tank
Holds 10 litres and relatively small
Mounted it on the rear bumper
same as this  one
http://www.ebay.com.au/itm/EVINRUDE-OUTBOARD-1-8-GALLON-OIL-TANK-ASSEMBLY-5008617-/201450136197?hash=item2ee75d2285:g:WKMAAOSwyQtViAcc
-- Edited by snapper49 on Wednesday 21st of October 2015 10:45:02 PM
Thanks snapper I will give this one some serious thought.
I bought a 5lt. yellow diesel fuel tank from Supercheap cost $19.50 a small battery box of eBay cost $17.50 and mounted the tank etc. in the front boot. Total cost $37.00 plus some small hose clips.
I modified the filler which comes with the container.
Chris
Every one dies but not everyone lives!!!
This is the one supplied with my Dometic Diesel heater  (Eberpacher)  10 ltr Diesel tank.
images?q=tbn:ANd9GcQSzDpIvGiqCbv1jaRtSYhcczEZonlbIuGKFECVXIrLhoelDA3dpw
Mike & Ellie
The Webasto and Eberpacher heaters are generally listed in catalogues without diesel tanks. That is because they have the option to be used from a small tank or for motorhomes they have the option of a 'T' piece to hook into the trucks fuel line or a take-off from the main tank. The tank that Mike pictured is the one that most fitters use if a separate tank is installed. Some suppliers may however offer a heater plus tank kit price.
-- Edited by PeterD on Thursday 29th of October 2015 09:22:55 AM
