Post Info TOPIC: Satillite dish
Satillite dish
I am about to travel and am not sure what Satellite dish to get...
Travelling for at least Two years and want one that that can pick up very good reception...Brand and Information
I went on this site not long ago about this question and lost the information..All information is greatly appreciated..blankstare
ms Karen Haring
Make an enquiry or call either www.satplus.com.au or http://www.accessantennas.com.au/
Either will give you valuable information and post to anywhere in Oz.
Do not go for the box type that sits on the ground, get a tripod mounted one.  Also need an easily removable LNB arm for better travel storage.
Cheers Neil
Neil & Lynne
Pinjarra
Western Australia
Hi  kassa;
             Satillite dishes also come in a few differant sizes and Vast recommend that you use a 80cm size dish, as one that is smaller has problems with trying to find the satillite in the northern states ( had problems my self  using a old pay tv dish ) also a spare LMB would be good insurance as well.
Good luck !!
hi guys. Try vansat. We have 1 and works everywhere so far.
vansat.com.au.
Lozza1956
PAY IT FORWARD, and SMILE
I can recommend Access Antennas, good support, good people.
Make sure you get a Big Dish, came across a guy who purchased a small dish online, they work well in the northern parts of Australia, but the further south you head the more problems you will have and in Tasmania they hardly work at all. With the large 80cm Dish you will be able to pick up signal all over 100% of Australia.
While you are at Access, make sure you spend the couple hundred dollars and get the BEST Satellite Alignment Tool for RV's I have one at it is brilliant. The most time I spend setting-up would be a couple of minutes. The current version is called Satlink RV sells for $179, It is often referred to as the Marriage Saver.
Don
Olympic SPX 21' Van - 2011 Nissan STX Auto
Try this link - wanting to buy a satillite dish
Just brought a 80cm kit from Access Antennas this arvo.
 Good Choice
Mike & Ellie
