Post Info TOPIC: any ideas what ?
any ideas what ?
finally it appears to be working thanks to all re picture sizing
found this in the corner cupboard  wires just disappear  into the wall ?so any guesses what it is would be good  looks like connected to 12 v ?
david heath
KFT
Could it have been the connections for a satellite box or a set top box?
looks like there is a coax in there as well.
frank
Avagreatday.
dzcook, welcome to the forum. May we see a side view of that thingo please?
pic of plug
david heath
Looks like a Power Supply for something, Sat Box or tv.  Can you put a multimeter on the centre hole & outside?  Will probably read battery voltage.
Neil & Lynne
Pinjarra
Western Australia
TAJ
could be for dvd player same as mine
Looks like the DC connector that powers my TV set. Same connector that would power the other appliances mentioned above. Do you have a multi meter to see what comes out of it?
The plug is a standard 2.1 or 2.5mm DC plug used to power all sorts of low voltage products as mentioned above. They are most frequently connected to 12V but depending on the item it was meant to power, it could be lower than 12V.
If you find it is 12V, I suggest you leave it there. You will find a use for it. The centre pin is usually +, but there are some exceptions. Check appliance and plug.
BJC
"A year from now you'll wish you had started today."
