Post Info TOPIC: Treatment for grey water tanks
I am going to fit a grey water tank to the caravan when I buy it later this year and have been researching treatments for holding the water. Unfortunately I have not been able to find much information 'on line' and called into BCF today but they were no help either. Should you use black water treatments and, if so, do you use the same dilution rates as for the loo. (Would have thought that as there are far fewer solids a lower rate might be recommended) or are there other products better suited?
Would appreciate you feedback/help
David
David
2014 Colorado Dual cab with canopy and boat loader
23 foot Western Homestead
If you always do what you've always done, you'll always get what you've always got
Not really sure if there is a treatment, but I put some napisan and disinfectant in the sink and flush it down, every week or so
Ken
DUN WURKUN
I do the same as Ken. Leave it in there to swish around then keep tap closed for another day then drain. Seems to work well.
We don't use any treatment per se, but put  washing detergent into sink/hand basin/shower and flush with hot water every now and then.
We also leave say 25% in tank and let it agitate around a bit as we drive to clean the bottom of tank and then dump.
I also cut a piece of garden hose and drilled holes along about 800mm (to match tank length) and when home insert into tank and turn water on and turn hose 360 degrees to clean/flush inside of tank, but this may be a bit of an overkill as in 8 years now never really had a problem.
-- Edited by Baz421 on Friday 28th of August 2015 10:29:41 AM
Thanks Ken, Dougwe and Baz.
So much knowledge available on this site
David
David
You got me on a good day David as I got up before Uncle Al today biggrin
What a coincidence. I have an Uncle Al too evileye'
David
David
A cap-full of napisan equivalent down sink and shower just before travel, then empty out when stopped at a dump point and all the residue and gunk comes out easily, once or twice a year pressure wash out with a drain cleaning attachment on a Karcher or similar.
brian
I put 1/2 cup engine degreaser in tank every 3rd or 4 th MT to remove any grease etc ..
We use. Dishwashing detergents and domestos most the time in general use..
Thanks Banjo and Aus-Kiwi. Your advice noted
David
