Post Info TOPIC: Engine noise insulation
G'day.
Home is a 1991 Mazda T 3500. It's a bit like the owner, older model, but well maintained. If you have one, or a Coaster, you sit next to the motor. The insulation under the bonnet is just worn out. Any suggestions on replacement, please ?
Pipes
pipes wrote:
G'day.
Pipes
Hi Pipes
I insulated my yacht engine room with a flat compressed sheet (like wool/fibre) which was fire proof and sound deadening.
I think you will need the same type of material but in a flexible type.
You could search under sarking which can be flame resistant and noise reducing. Here's a site to help:
http://bradfordinsulation.com.au/residential-insulation/roofing/roof-sarking/thermoseal-sarking
On this site above there is a section for what you want and they show the products.
This is also a good site to research and maybe ring them.
http://www.tbafirefly.com.au/bush-fire.html
Also a welding blanket may help but may not be noise deadening enough, see this link:
http://www.ic-international.com/hightemperaturefabrics.php
I'm sure there are more like this.
Hope this helps, but be sure to get something that kills the noise AND is fire resistant/fire proof.
Cheers Baz
Thanks Baz. I'll look them up.
Have a look in Supercheap, Repco etc for engine insulation. It's in rolls and sheets and designed with some self stick on one side for installation, Like under a bonnet. Also Whitworths ( The Marine and Boat stuff) they do three different types from sheets to rolls.
The Whitworth's stuff is on page 50 of their online catalogue  cat nos.80200N   80202N and 80204N
Hope you find the stuff that suits your job
-- Edited by Yuglamron on Friday 7th of August 2015 01:22:40 PM
Clarke rubber sell a silver backed rubber sheet ,comes in a roll and has a sticky back that I found wasn't all that good anyway ,I use it on the engine bay of the race car that runs at about 110db and quietness quite a lot, haven't thought about it for the coaster but not a bad idea. Although with the 308 I only get a little induction noise anyway.
Dennis and Yvonne .
Retired sparky of 50 years.
JUST COASTIN`
I am also looking for some kind of matting to replace the worn one between the two front seats of my Toyota Spacia.  It sure does get hot sitting next to the engine.   Have sent an email to Bradford Insulation as Baz421 suggests.  It needs to be noise proof and fire proof.  Will post outcome when I receive a reply from them.
Cheerio  June C.
Thanks for all the replies. Just spent a day and a half pulling the heater system from out under the dash. Not fun.
Regards'\.
Pipes
pipes wrote:
G'day.
Pipes
 Reply from Bradford Bats - 'We don't manufacture a product that would meet your requirements'
June C.
June wrote:
pipes wrote:
G'day.
Pipes
June C.
OK one down,,, one of my other links was this stuff,,
 http://www.tbafirefly.com.au/compartment-barriers.html
KFT
G'day Pipes
have you had a look here?
acoustica-px.rtrk.com.au/transport.html
they appear to have quite a range for marine and automotive applications
hope that helps
frank
Avagreatday.
