Post Info TOPIC: Jayco Head Unit
Jayco Head Unit
The head unit in my jayco Motorhome has went haywire, when I turn it on it might say store,or clock set or a Radio channel any thing but the right thing. None of the buttons does anything. It should let you choose TV,RADIO or PHONE. Anyone got any ideas?
Kevin
Wannabes
Kevin
 Try disconnecting it from the battery power, and reconnect after 10 seconds or so. There are normally 2 power connections, one direct to battery for main power, and a second wire that will be connected to the 12V power when you turn your 12V supply on. Pulling the plug out of the back of the Stereo Head Unit is the easiest way and should disconnect both wires.
Thanks Troopy, Will try that tomorrow.
kevin
Wannabes
