Post Info TOPIC: water pump question
water pump question
I have a Jayco Heritage. Water Pump has stopped working. I checked the fuses, ok. Does anyone know if they have an inline fuse that should be checked before I go out and buy a new pump.  I couldn't see one. Thank you
Mechanised Swaggies
Check the supply at the pump ,could be a fuse or the pressure switch in the pump however they are pretty reliable. A multi meter or test lamp will do the trick. Might save a bit of cash.
Dennis and Yvonne .
Retired sparky of 50 years.
JUST COASTIN`
Hi Neil and Raine. I have a Jayco Dove Outback and had the same problem. It turned out to be simply the switch. The switch on ours is built into the kitchen bench beside the sink and had corroded due to water seeping into it. It was easy to replace, this time with a water proof one.
Rod.
Rod.
Ah! The serenity
Is the pressure switch on the pump serviceable or replaceable? This could also be the problem.
Hi Neil and Raine, Did you manage to sort out your pump problem ?.
Rod.
Ah! The serenity
