Post Info TOPIC: Replacement of Dometic toilet float
Has anyone replaced the toilet cassette float in a Dometic CTS3110 toilet.
I have to fit a new one and am not sure if the magnet in the float faces up or down.
any advice would be appreciated.
I think magnet would be up, as the float rises at the bottom the magnet makes contact at the top.
Thats was my thought until I saw an image in the service manual which appeared to have the magnet facing downwards, because I have not seen one installed I only want to install once.
I think the design leaves a lot to be desired, mainly the pivot point attachment.
I have seen complaints on various forums (local and international) about the design as far back as 2009.
Well, according to Dometic, the magnet faces down.
See attached fitting instructions.
-- Edited by migra on Thursday 23rd of July 2015 02:23:16 PM
 OK, I must say I'm surprised by that. The magnet contacts a switch outside, it doesn't make sense that it's on the bottom. Then again, it's dometic, mine is a thetford.
Oops next time I will read dometic not thetford  sorry
-- Edited by Phil C on Thursday 23rd of July 2015 07:56:58 PM
Thanks for the reply.
Same here, I spoke to Dometic direct and they also sent a installation sheet which has the magnet downwards....they advised to install as per the instructions.
Which I will do !!!!!
