Post Info TOPIC: Slide on campers
Slide on campers
Hi,
Has anyone got some experience, advice re slide on campers please.
Janette
Hi,
We are in canberra.  When first retired started travelling with a Bute camper made in QLD (bit like a camper trailer without wheels), reason for the slide-on was we wished to take our boat.  We kept it for several years and undertook many trips thru victoria including the great ocean road and up thru QLD as far north as Weipa where we stayed for several months.  We eventually traded up to a Northstar slide-on, again for several years and many miles and trips latter saw Darwin, Kakadu, Karumba many of the QLD dams.
The Bute was reasonably light on the ute and good to travel with.  The only matter that caused some discomfort was it had a lot of canvas and after several weeks in very wet weather in QLD we decided to sell it.  The problem with all that canvas was that even though we did not get wet, we always had that sort of damp feeling.  Notwithstanding that it was comfortable and served us well.
The Northstar, being hard wall (pop top) was comfortable and we travelled as far as Darwin, Kakadu, Karumba and thru QLD dams.  We sold it and bought a caravan for two reasons, firstly we decided at our age we wanted a bit more comfort and room with less setup time, and secondly the quality of materials used in the Northstar was average and some problems were starting to emerge.
Whatever slide-on you consider you need to have a good awning system with walls to expand the living area.
You also need to examine closely the weight of the slide-on and the travelling contents.   Regardless of the claims of sales staff, you will end up very close to the vehicles GVM and quite possible over the GVM
regards,
Hi Johnwf,
Thanks so much, a very helpful post. I've been considering a slide on for a long while now, the weight issue and putting it on and off concern me greatly. Quality issues and set up time I'm totally unaware of, so great to hear others experience.
Thanks and regards,
-- Edited by jetj on Wednesday 24th of June 2015 01:08:29 PM
Janette
Jetj,
Loading/unloading a slide-on is fairly straight forward, just remember (depending on model) you may only have about 30mm each side of the vehicle tray to slide-on leg clearance.  The main problem is that you need a straight line to reverse under so you often need a fair bit of room infront of the slide-on to get the vehicle straight (not like a caravan where you can come in on an angle to hook up if need be).  Once you get the hang of it everything works OK.
The other hint is to get electric operated legs if you can afford them.  It makes a single person operation and they are usually also individually leg operated which makes it quicker to level up when lowering for camping and also for adjusting the slide-on level when loading/unloading on uneven ground.
regards,
i have travelled 105,000km over the last 2 years on most of the worst roads this country has to offer in my slide on and never had a issue and find it allows me to access places like the Bungles and have a little bit of comfort at the same time.
Personally, for experience and from what i have seen on my travels i would not even consider a slide on if you intend putting it on an extra cab or dual cab.
the payload of the vehicle decreased greatly in these configurations, and most of the weight is behind the wheels.
by the time you put a slide on onto a dual cab or extra cab vehicle you have exceeded the vehicle capacity before you, your gear, fuel and food are even considered.
i have seen 3 bent chassis on dual cabs in the last 3 months, not from slide ons but overloaded.
happy Travels :-)
http://livingthedreaminoz.blogspot.com.au
Baz
Thanks Baz and John,
Your advice is much appreciated.
I've been following your blog closely for ages Baz. I'm amazed at what your vehicle and slide on have done and coped with. Probably the reason for my wanting a slide on.
Janette
believe me .................it has surprised me also!!!!!!! what a cheap chinese ute and a slide on will do !!!!
just goes to show, with a bit of care you dont need to spend hundreds of thousands of dollars on your setup.
mine cost $43,000 new for both camper and ute.
this has allowed me to do the things i want to instead of dreaming about it.
ps. updating blog to include Bungle Bungles and Bullita outstation in Gregory National Park probably tomorrow
cheers baz
happy Travels :-)
Baz
Thanks Baz, I will check out the new entry, I tend to check every week if not more often.
Janette
Thanks for your info Baz. I wonder if 2016 has produced any advances in the slide-on Units? EG. Are full height, tray backed, non-pop-tops seriously safe?
MS
Believe me after carting my slide on over 130,000 km around every crap road in australia any vehicle combination is only as safe as the nut behind the wheel.
i have seen numerous people get themselves into all sorts of trouble and without doubt most of it is user error.
overweight and in too much of a rush is the major is the major culprit.
slow down and enjoy yourself and your problems will mostly disappear.
personally i would not go to a full height slide on as it limits access too much to tight areas
happy Travels :-)
Baz
Hey Baz, thanks for your reply, I like the way you're going about things.
I am still researching the slide-on rig I need and would welcome any advice: I can't tell from your vehicle picture, do you have 4wd and do you find it necessary? I would definitely like to try the non-tarmac roads/sites but just wonder how far and how long you can go with the limited resources/weight of a slide-on camper? I'm not wanting to Bear Grylls it, and I'm really not that interested in Grey Nomad Happy Hours, I just want to get out there and see what I can on a limited budget. Being a veteran traveller, I would really appreciate your advice.
MS
Hi Superb Blue
My vehicle is a 4x4 and I wouldn't have it any other way. the best places are accessed along bush tracks and rough roads. Not only do you get a more robust rig but it also gives you the clearance and safety net of having the ability go a lot more places.
In reality, the Gibb River Road for example is Doable in a good 4x2 when the creek and river crossing are low, but I wouldn't want to buy it off you when you are finished.
I carry 145 litres of diesel (over 1000 kilometres of range), 95 litres of water and a freezer and fridge of food. My limit is my 8.5kg gas bottle which lasts me 8-10 weeks.
The Ute capacity is 1100kg, the camper is 479kg dry, add food, gear, fuel, water etc and I'm probably up around 850kg fully loaded which it handles comfortably.
I am currently in Darwin and the biggest problem I see is too many people. Two years ago I camped at Butterfly Springs on the Savannah Way and was one of two camps. A few weeks ago I camped there again along with 25 other camps. After at least a dozen times in Katherine I have never seen so many travellers around.
The other issue is that there is a new breed of traveller around now that are irresponsible, selfish and inconsiderate. They travel at dangerous speeds on gravel roads, don't slow when approaching oncoming vehicles, don't stop for others in trouble, and make camp to maximise their area and keep others out.
Part of the problem is someone with little 4x4 experience, little towing experience, can go out and buy a caravan the size of an inner city apartment and a 4x4, then think they own Australia and take it any where at any speed they want too, then run the smelly generator all night.
i am satisfied with what I have, and think if you need to tow a small apartment along to make you happy you should seriously consider staying home.
Not everyone can afford, or wants to spend the majority of their Super Payout on a rig that is so big it need it's own postcode.
KISS Keep It Simple Stupid principle works for me.
My advice......
Don't spend all your money on your rig, save it to enjoy being out here
Slow the Hell down and enjoy what you have spend your money to achieve ( and suffer a lot less damage).
Allow plenty of time, don't overcook your destination. 600k a day of gravel is not enjoyable!  often a tank of diesel lasts me several weeks cutting costs considerably
lastly I hear you about Happy Hours. I don't enjoy 50 people trying to out shout each other to tell you how good their grandchildren are.
-- Edited by solo nomad on Friday 15th of July 2016 11:49:29 AM
happy Travels :-)
Baz
Thanks for that Baz.
MS
Gday Team,
I am also new to the forum and about to get organised with a slide on camper on a Hilux DualCab.
I am looking to the Trayon Dual Standard with a few extra's.
Has anyone got any clues for me?
There will only be 2 of us travelling and we are upgrading from swags.
I will be upgrading the suspension and the front discs on my vehicle which currently has a payload of 1340kgs - 350kgs of Bull bar/tow bar and steel tray = 990kgs standard payload available now.
This will increase with the suspension upgrade and certification.
The Trayon is 370kgs dry.
Please do offer any advise you may have for me.
Kind regards
Country
