Post Info TOPIC: coromal 505 1998 pop top ceiling fluros stopped working, all rest elect ok, any ideas please
Ceiling fluros stopped working suddenly , all other electrical supplies are ok. any ideas please
Hi, Warren!
You would have to suspect a wiring fault if all just stopped at once. I'm not that familiar with pop tops, but you should find some sort of flexible cable running from the bottom section of the van to the roof. If that looks OK physically, i would need to know what sort of fluoros they are. Do they work without mains voltage or not? If they run from the battery, you could check the 12v with a test lamp. You may also need to check for a blown fuse. I'm also sure that there must be Coromal pop top owners out there who may be much better help than I can. It's probably a burnt wire connection somewhere, and if that's the case, finding it can be tricky.
Chris
Best regards,
Chris
Licensed Electrician, Electronics, Gaming & Computer Technician. Now retired and loving it!
There is a Coromal facebook group . You should get a reply if you post there. There a few Coromal service people who can help
www.facebook.com/groups/coromal/
Im guessing you checked the fuses ??
My coromal has a very comprehensive array of fuses
On pop tops there is usually a lead that connects the power to the lights in the roof. It usually plugs into a point in one of cupboards around the top of the van. Check this plug to make sure it hasn't come out of the socket.
Bill B
