Post Info TOPIC: Alternative HWS
Alternative HWS
Is there a cheaper version of HWS availabale other then Truma. I am thinking of gas only because we only use it while freecamping.?
thanks vic
Hi Vic
Have a look at this link ( dont use it inside caravan )
http://www.ebay.com.au/itm/Instant-LPG-Portable-Gas-Hot-Water-Camp-Shower-Heater-4WD-Caravan-Horse-Dog-Wash-/251656990633?pt=LH_DefaultDomain_15&hash=item3a97ecefa9
Cheers John
Hi Vic,
Have a look at this unit. Fits in the same place as your Suburban SW6DE.
Larry
www.ebay.com/itm/Girard-1GWHM-Tankless-RV-Water-Heater-/111547766954
I have the hot water service as the one in Larry's link. They are good BUT seem to be better on mains pressure than through the pump in the van. They take about 2-3lts to start getting hot. Took a bit of getting used to.
Here in tropical Townsville, Queensland as a southerner I don't even need hot water, a cold shower is great first thing in the morning. I have been here 5 weeks now and forget what a hot shower is.
Hey Chief,
You are the first person I have come across that uses that unit. I am glad you are happy with it.
Larry
Be careful about buying the type of Hot Water System that Crusing Cruse shows in his link,
I bought one last week, off "Evil Bay" after seeing one advertise with a picture of one attached to a caravan,
After it arrived I unpacked it and found a small sticker attached to the side stating " NOT COMPLIANT FOR CARAVANS "
When I went to return it, I found, YES the Seller would give a refund IF I payed for the return post and after they took 15% off for handling expenses, this meant I would loose around $60 -$70 !!!
I did the only other thing possible to get as much back as possible, that was flog it off on GUMTREE.
Luckily it sold straight away, and with only a loss of $ 19.00 to me.
So be warned,  make sure before you buy that the appliance has AUST compliance for use with a caravan.
K.J.
From Coast to Coast, We'll see it all.......One Day
U.H.F  CH  18 /40  Say G'day.
thanks jim, i will check with my gas guy, my truma is leaking.
I Clearly stated that you can't use it inside the caravan biggrinbiggrinbiggrin
One bloke from otherwebsite made a box where he instalted one nifty idea I think
Cheers John
-- Edited by Cruising Cruze on Saturday 20th of June 2015 12:28:06 PM
Thanks john , buts its not for me. i will keep looking.
vic
