SmartBar Camp Creative
Post Info TOPIC: Swift Caravan Cookers - ALERT
Swift GroupSwift Caravan Cookers PRA number: 2015/14707 Date published: 25th May 2015 Product information Product description Caravan Gas Cookers Identifying features All cookers up to 5 years old by date of caravan purchase. (Cookers are required to be regularly serviced but must be checked by Swift after five years). What are the defects? The caravan gas cooker has not been installed with adequate support in the cavity in accordance with AS/NZS5601 in order to prevent movement.
What are the hazards? Excess movement or vibration may cause the cookers fitting lines to leak, posing a potential risk of explosion or fire. Where the product was sold Nationally Traders who sold this product Various caravan manufacturers Supplier Swift Group Supplier's web site http://swiftappliancegroup
What should consumers do? 1. Contact a licensed gas fitter to check that the base of your cooker has been supported and/ or the top frame is braced to prevent flexing. If you find that the cooker is not supported as per the installation instructions and requirements of AS/NZS 5601 you must contact the caravan manufacturer to have this rectified and 2. The appliance must be checked by a licensed gas fitter for any damage and leaks. Fitting a gas leak detector is also recommended 3. If you are unsure of how to assess the installation or you are unable to contact a caravan manufacturer because it has ceased trading contact Swift for further advice on: 03 93593068 or by email accounts@swiftappliancegroup.co.au More information can be found in the attached Gas Safety Alert.disbelief
Hi Migra. Tried to open the swift appliance link you have posted, but wouldn't work, so I sent them an email last night.
Thr response was good. It has nothing to do with the Swift product, but once again we have manufacturers not doing a professional job - in this case, not fitting them into an adequately secure and strong base as recommended by Swift.
I asked if my brand was ok - Supreme - the answer was yes - Supreme install the cookers, stoves and grilles correctly.
Swift have spoken to all the manufacturers who use their product and asked them to contact customers through the Dealer network - lets see how many people get notified !
Suggest you go on to Swifts web page and email them with the details of your van and they will tell you if you might have a problem or not. Swift point out that the manufacturer is required to rectify the problem at no cost to you
Cheers Bruce
Try www.swiftappliancegroup.com.au/index.html
2015 Ranger XLT - 2014 Jurgens Sungazer
Had me worried--until I went to the link and discovered it was for an appliance maker called Swift, Not the caravans made by Swift, a different company.
2017 Jayco Freedom + 2 miniature Schnauzers.
Thanks for the tip Migra
I contacted swift about my condor and said he was not sure, then explained what the problem was, so while he was on the phone went to my van and had a look
The cooker is fully supported and all ok
Told him I had installed a gas detector and put in the van, and he told me to put it in the drawer under the cooker as by the time my alarm sounded where I had installed it, the van would be half full of gas and explosive.
He is sending me another alarm to wire in under the stove, good service and advice
If you have a swift cooker please check it
Ken
DUN WURKUN
