check out the new remote control Jockey Wheel SmartBar Topargee products Red Earth Festival Park Booker
Post Info TOPIC: Rangehood over gas stove
A friend is building a caravan in VICTORIA, AUSTRALIA.  He wants to know where to find the tech-specis for the required clearance above the gas stove.
Suggest he goes to a caravan yard with his tape measure
Rangehood in my converted Hino is 530mm above the stove, was done by conversion company which seemed to be conversant with gas regs (for Queensland at least) when we were discussing positioning of a gas bayonette fitting to comply with the then-upcoming new regs (think they came into force last July).
Joe
AS5601 says quite clearly 600mm clearance from the top of the trivet.
AS5601 Part 2, 6.9.1
Where the required clearance to a range hood cannot be met, a range hood constructed of non-combustable materials may be installed at not less than 450mm, provided the manufacturer states the range hood is suitable at the installed clearance and the gas appliance is certified as a caravan/marine cooker.
-- Edited by Spook on Tuesday 26th of May 2015 05:00:17 PM
-- Edited by Spook on Tuesday 26th of May 2015 07:23:08 PM
If there are no dogs in Heaven, then when I die I want to go where they went.
My girls are Misha, Maddy, Morgan and Muffin. RIP Jen, my princess.
RIP Molly, our dear girl who crossed the Rainbow Bridge 24/10/2016. A loyal and faithful companion.
Youll find there will be a flame proof filter ? Looking at ours .. Its under 600mm easy..
Vented outside using metal ...
The above is quoted verbatim from the Standard...............there is no discussion necessary. It either complies or it doesn't.
 Alex, all the relevant info is in AS5601, Part 2.
And DITTO to thatbiggrin
The thing is to compare the stds to what you have ..
