Post Info TOPIC: Faulty INFINITY CABLES
Just a reminder if you could have the faulity cables installed in your home or RV
http://www.accc.gov.au/media-release/do-you-have-dangerous-infinity-cables-in-your-house
There is still 3500kM not accounted for
  Do you have any in your home or RV??
PeterQ
Thanks PeterQ, hope you are well.
I would imagine if the manufacturers used these cables they would recall the caravan (at least I hope so). In my jayco they use a round cable for their 240 volt services which is a pig of a thing to work with. The cables are not infinity so I think we are safe.
Am I correct in assuming caravan manufacturers should not use TPS but a stronger cable (vibrations and rubbing etc, TPS may fall apart.).
Cheers and thanks again
Hi Phil
TPS is Ok, but it must be min 7strand.
Requirments covering mechanical damage fixing & additional protection are covered in AS3001 cl3.4smile
PeterQ
OK fellas - what is TPS please. In cars it means Throttle Position Sensor.
 Hi Hako
Thermplastic sheathed wink
There are different grades of heat tolerance [thermo plastic]
PeterQ
I doubt if any caravan manufacture even has a wiring diagram let alone worry about where the cable come from. Most I have had anything to do with don't even have a sparky on staff once the original wiring layout is approved . Cable are installed by whoever is available on the day to run the cables via the shortest route. What can be a bigger concern are the staples they use to secure the cables to the wooden frame . Not sure how they secure cables in alloy famed vans probably sticky tape, who knows
 I guess we are lucky with our Jayco, they have the cables in a form of trunking and vertical risers makes it a bit easier to work with. I have worked on a caravan that had short point to point runs that would have turned into a nightmare of guess work without my trusty F set cable tracker and volt stick.
I guess cable is expensive, and yes non trades people do install the cables (which I believe is legal) and sparkies do the connections. Cable ties generally secure the cable runs although in my roof the insulation material holds the cables down and in placeno
