Post Info TOPIC: Fridge dead but freezer section OK
2 door Dometic RM7851l - the freezer box is working OK but the fridge section not working at all.(same on gas or 240) Wondering if anybody has ever had a similar experience and what the solution was??Currently in Karratha but can't blame the weather as its only 30 today
Jenny and Barry
Stl
Hi, I had fridge problems ( turned out to be faulty cooling unit AND thermostat ) but one of the things they checked was to make sure the cooling fins were not broken or had come away from ???. Apparently they run from the freezer down to the fridge but they can come off the fridge part so freezer works but not the fridge? That's here say, hopefully there is somebody with more knowledge that will be able to help. Best of luck.
Just another day closer to dying...MAKE THE MOST OF IT.  :))
I had the same problem what happened the flue had come off on bad road
