SmartBar Floriade Darwin International Film Festival Goodlife RV Resorts Celtic Fest
Post Info TOPIC: Induction Plate
Induction Plate
I have an induction plate, which has adjustable Watt control, from 500w 1000w 1500w and 2000w. then also variable temp control from 65deg to 220deg. Can some one tell me what the different Watt setting do?.
Greg
-- Edited by gregnshas on Friday 24th of April 2015 11:30:24 AM
Greg & Shas
"Take kindly the council of the years gracefully surrendering the things of your youth"
Surely it means that if you select 500W the plate will draw 500W to heat 'whatever' to the selected temperature. If you select 1000W the plate will draw 1000W to heat 'whatever' to the selected temperature twice as fast because it uses twice the power.
This would be handy if you only had a 500W inverter to run it on.....just would take longer to heat than the higher settings.
Can you supply the brand please as it sounds handy.
Hi Denis,
Thanks, for your explaination, but I seriously couldnt tell the difference in time boilig water at 500w compared to 2000w, but I will try again, The brand is Ecoheat, and the specs are below, they say you need 1000w inverter to run from solar, So i'm going to try that at the weekend. We love it, instant heat, and so quick.
Greg
Premium portable induction cooker. Variable power options, 2000W, 1500W, 1000W and 500W. Suits any standard 240v, generator or solar/inverter use. Incorporates built in BBQ function. Tough in-vitro cooktop, auto shutoff circuit board. Variable heat settings 60-220ēC.
Power 2000, 1500, 1000, 500 watts
Amps 8.33, 6.25, 3.12, 2.1
Hertz 50, 50, 50, 50
Heating 60ēC - 220ēC
Weight 1.5kgs
Dimensions
Greg & Shas
gregnshas wrote:
Hi Denis,
Greg
Weight 1.5kgs
Dimensions
 HI Greg
If your inverter is only 1000W continous   rating then you should only run  the hotplate on the 1000W setting
IF inverter less the 1000W continuos rating then you will have to use the 500W setting
The other problem is the induction hot plate may draw Amps from the inverter than you would expect, 1000W divided by 240V would equal 4.16A[ their 3.12A is wrong]
This is due to an effect known as power factor & the actual current will be higher than the caculated
PeterQ
-- Edited by oldtrack123 on Friday 24th of April 2015 08:31:14 PM
Thanks, for the advice, and thanks Peter, I did a test at the weekend and the induction plate ran beautifully on 1000w no problem.
Greg
Greg & Shas
