Post Info TOPIC: Towing with gu 4.2 turbo
Hi, can someone advise, I have a 2003 GU turbo diesel and wish to purchase 20' caravan than will fall into 3 - 3.5 tonne range, does anybody have prior or
existing experience with this combo, cheers Peter
Welcome to the gang Peter, enjoy here and out in the playground.
Sorry but what is a "GU"? Make of vehicle etc? If it has the tow capacity of 3.5+ t, I see no reason why not however, it is getting up there to max weight allowed. I personally like a bit of space with the max weight. I have a van that is around 2.8t and a car that has 3.5t capability to give me that spare weight as to not overwork the beast.
From what I've read over the years, the 4.2 TD is the engine of preference in the Patrols and seemingly bulletproof, so I'd say you have the right vehicle.
Good Luck and welcome to the forum.
From what I've seen/read.. they're almost as good as the Tojo 4.2 TD's .. you shouldn't have a problem mate.
Firstly -
Secondly - Perhaps this information will be helpful.
Thanks for the advise, I did not mention the Nissan was 4.2, 9.5psi @ turbo 130hp @ the rear, cheers
Hi Peter
Towing at the max will show the short comings very quickly (stands to reason), if you have a look at http://beauexhausts.com.au. These guys are very good at what they do and having 2nd person experience it makes are huge difference to the towing performance. Their product is so good they actually fit better than the original system.
Some say you even get better fuel economy but my experience is that you tend to drive the veh a little harder and that destroys the economy but lot of fun, either way it's worth a google or a call.
Winnebago Freewind 2004
Thanks Peter,
Didn't give all info have 3'' stainless with 3'' dump, so with the feed back from the forum I feel comfortable @ ATM of up to 3200kg, looking @ Skytrax 'Frontier' or Option RV 'Traction',
the latter being 3400kg and the former 3100kg, once again appreciate feed back, cheers
Hiya Peter,
I also run a Gu patrol (05)
Doug is giving sound advice - it is good to have a fair margin. I don't want to run about with 3 and a half tonne behind me.
An auto transmission will mean a lower weight capacity.
cheers from another sandgroper.
Techno (Bob)
avatar?id=1579114&m=75&t=1428155969
2005 Patrol 4.2L Cab Chassis
and "Wanda" our 2014 Safari 18.6 X-Trak
  • VKS737 Mobile1328
  • UHF Ch 18 / 40
