check out the new remote control Jockey Wheel SmartBar Topargee products Red Earth Festival Park Booker Mackay Festival of Arts
Post Info TOPIC: Truma hot water system
My 4y/o truma hot water system only heats on gas, not 240v. It trips the safety switch in the motorhome and house when we turn it on to 240v.
We went over a really bumpy dirt road near braidwood nsw and it hasnt been the same since.
is it worth while repairing or replacing and if i do replace , what with?
We are back home in bundaberg now, any help appreciated.
why don't you drag it down to your local auto electrician and get them to have a look - most don't charge just to look and give you a price to fix. It may be just a loose wire or something else that wont cost you your arm, leg and head
Cheers Bruce
KFT
Very likely the 230 v element is faulty which is why it trips the RCD
a local caravan repairer should be able to check and replace it for you
an auto electrician would most likely not be experienced in this type of unit.
frank
Avagreatday.
Hi Clarence, I agree with KFT,sounds like the element or wiring within the unit.I just replaced my unit after it developed a leak(six years old).The cost was $890 plus gas certificate $50.(gas /electric unit)....cheers Peter
Some political leaders and babies nappies should be changed often for obvious reasons.
Pop it down to Casey's at Island St in Bundy,
I had what I thought was a terminal problem with my water heater and they fixed it.Told me it was only a leaking pressure relief valve and replaced it and all good.
They could have easily replaced the whole unit which I was expecting.
Saved me lots and were very helpful. I have no connection with Casey's other than a very satisfied customer.
Hope you get sorted out.
Thanks all , i booked it into Barron refrigeration, they have done work for us in the past. Maybe next time i will try casey's have heard other good reports about them , thanks yuglamroon.
Chances are if its just the RCD tripping . It's moisture or condensation on bare electrical parts ..
If it was the breaker ? You would possibly have bigger issues??
Yes get it checked by Experts in this field..
I like the fact that it still works on gas (hasnt totally **** itself),, hope your right Guru.
VIC
