Post Info TOPIC: DOUBLE STEPS
DOUBLE STEPS
Hi Everyone, We are at present on uneven ground with the door side of the caravan higher than the other side. Therefore, the door if higher off the ground and we need 2 steps. We have a 1 step that is no enough. any suggestions? thanks.
Got a Tool Box or a strong plastic crate/box that you could use upside down as a temp measure???
-- Edited by madaboutled on Saturday 21st of March 2015 10:14:17 AM
Don't whatever you do get one of those Fiamma plastic "ankle breakers" type steps, they quickly die due probably to UV and become brittle.
Better alternative is one of those alloy type with fold out legs on each corner, very stable and strong but light too.
brian
Rock, block of wood, box or just get a run up and jump.biggrin
Hardware stores (Bunnings etc) have light plastic folding stools that appear to be very stable and fold down flat for storage/transport.
My wife says I never listen to her... well I think that's what she said.
Find a new parking spot that is leveller biggrin
Bill B
This works well for me rocket,
Sorry Rocket I can't seem to correct the view for some reason.
Only buy the one Doug has posted , Can buy them at repco or super cheap , 2or 3 years back a forum member had a nasty mishap use an up turned milk crate . Plastic has it gets old are like us get very brittle.
This happened to us as well. Hubby had two solid flat bits of wood, I think he'd used them as levellers under the van at times, anyway he sat those under our step but put big screws in the wood around the step legs so that the step didn't move when we stood on it. Hope you got what I mean?
Cheers Dianne
Quo vadis
Keep watch for the Aldi double step. $30.00. Most of my friends have them as well.
Dick.
I'm a milk crate person.  Always carry two or three.  Keeps things from bouncing about & great for steps, footrests, stove stands, shoe boxes et. al.
Maybe a couple of sand bags they won't tip over.
Lance C
We use a milk crate. Now on the mark 3. The chauffeur has run over a couple.
Dick.
 This is what to look for :
http://www.discountstoresau.com/aldi-catalogue/aldi-catalogue-february-deals-2014-16.html
We have one, but we don't use it in the Aliner - my wife has a very extensive library of over 10,000 books (collected over 45 years) in 18 bookcases 6ft high with other books placed on top - we use the caravan steps as mobile 'library' steps to get to the top of the bookcases. Also found them handy to do a few little DIY jobs around the house where a larger step ladder gets in the road !
Shorty - that A van must be like Dr Who's Tardis ?
Bigger on the inside than out.
That's how you get all those books in there !
biggrin  biggrin  biggrin
avatar?id=1579114&m=75&t=1428155969
2005 Patrol 4.2L Cab Chassis
and "Wanda" our 2014 Safari 18.6 X-Trak
  • VKS737 Mobile1328
  • UHF Ch 18 / 40
 Hi Rocketeers,
We had that problem sometimes and got sick of it. Also the step normally was bigger than the higher ones in the MH. So I removed the single step and replaced it with a double step. Perrrrrfect. biggrin All the steps are very similar if well parked.
A bit of mucking around and some work but much better. Bought it from a caravan place. The step looks similar to yours but has another bottom step which folds up onto the top step before you put it in. To put out you lift and pull out, then unfold the bottom one.  wink
-- Edited by Jaahn on Sunday 22nd of March 2015 09:40:57 AM
This is the one we use. It's similar to the Aldi one but it's always available, not just when Aldi decide to supply them.
There are various others at this page. They are available at any Camec stockist.
Yeh ! that's been a sore point since we've had the Aliner - every trip, SWMBO always brings at least 8 books, weighing up to around 12-14kgs - I keep telling her if she keeps bringing more books, I'll have to turf some of her other stuff out of the van to keep the weight legal ! biggrin
thanks everyone. We bought a double step portable one. Now I can get in and out of the van. cheers.
ShortNorth wrote:
Dick.
Yep, that's it.wink
Dick.
