Post Info TOPIC: Waeco won't work on 12 volt
We have a 5 year old waeco that will no longer work on 12 volt. It works very well on 240 but shows a red error light as soon as we switch it over. All the leads are good and 12 volt plug.
 Gail
"Started wandering and don't wish to stop!"
If you search there is a lot of info on Waeco fridges in this forum. Also what is the model number of your fridge?
D.L.Bishop
KFT
My waeco does that unless I turn it off before unplugging the powerpak and then turn it back on again all is ok
I usually get a low voltage alarm(red led flashing)
frank
Avagreatday.
I have an old Engel and it won't work on 12 volt either the cost to repair was way too much. So what i did was i bought a 300 watt inverter and run it in the back of my car. Hope this helps if yours woRks out cost prohibitive to repair
Cheers Terry
Try this - www.youtube.com/watch
This ia common problem - forum.australia4wd.com/index.php
I had the same prob when mine at around 5 yrs check the fans, mine needed replacing and has worked fine ever since
Also check inside 12v plug may have a fuse
steve & cheryl
70 series cruser & 16ft new age mantaray
There is a good article by DeBe on the Waeco powersupply here:
http://thegreynomads.activeboard.com/t42448120/waeco-powersupply/
