Post Info TOPIC: Our Ranger Fitted Out
Almost finished now.... is that possible?
The next project is a suspension upgrade (if required)....
Now, to fill the drawers and find time to get away for a test run with the caravan hooked up behind.....ranger-a.jpgranger-b.jpgranger-c.jpgranger-d.jpg
Mike Wharton
2014 Ford Ranger XLS
Retreat Keppel
www.timetoretreat.com
Looks great Mike
What did the drawers set you back, have been thinking about them for a while, just have not won lotto yet
Ken
DUN WURKUN
ken thomas wrote:
Looks great Mike
Ken
the drawers cost $2569 fitted. This included the side panels where extra storage is provided. The second battery is under the passenger side panel and there is room for tarps etc under the drivers side panel. A lot of $$$$$ but I feel it is worth it to have things stowed away securely. The drawers are 1255 X 435 mm (full length)
Mike Wharton
Retreat Keppel
Looks good Mike.
Discovery 4,
Retreat Brampton
Shut the front gate!
Nice looking Tug Mike. It's too shiny though mate, maybe a trip to Greens when muddy is needed.
sounds like a plan!!! (my only problem is trying to fit it in between grandkid's sleepovers and kids birthdays. Every time I suggests a date something comes up to stop it from happening. I might need to come away on my own smilesmilesmilesmile
Mike Wharton
Retreat Keppel
ken thomas wrote:
Looks great Mike
Ken
 Ken, as a matter of interest... what L / 100K do you get under tow?
Mike Wharton
Retreat Keppel
Hi Mike'
It's a good idea to keep an eye on the weight when you start modifying. My 3lt BT50 has similar mods. With full fuel tank, 25lt spare fuel, 10lt water, (no bodies) it is 600kg over the kerb weight. Fuel economy went down 1-2 klm/lt after adding extras.
Cheers Pete
Thanks for the tip Pete.
Mike Wharton
Retreat Keppel
Pretty smart looking dual cabs.
I like the roof rack on the Pete's one, is that a trade brand and will you be able to put much weight up there.
They are so practical for roaming about.
Here mine, just love it. ,Ralph.
-- Edited by Radar on Monday 12th of January 2015 08:24:18 AM
Hi Ralph. I decided against the full roof rack so I was not tempted to load up the tug too much. Even with what I can fit inside I am going to have to be careful I do not load it up too much. I think that the fox-wing awning is going to be useful but I am still not totally convinced I did the right thing adding it as it is weight and resistance that will decrease my fuel efficiency. In time it may be removed.
Mike Wharton
Retreat Keppel
Hi Mike,
I had the awning off the side of the Land Cruiser on the roof rack. Used it once. Found the roof rack very handy for wood collection.
Snail
The best pace is Snail's pace
Hi Ralph'
I made the rack up myself. It started as 2 bars on the canopy. The side rails are attached to the bars on the canopy & the side rails support the front bar. It's based on a production ARB set up. I wanted the extra length as I carry a couple of 4 meter kayaks.
I think the bars on the canopy were rated at 70kg each. It's an EGR plastic canopy. I had to fit  support braces inside the canopy to support the roof rack.
2 kayaks only weigh 40 kg. I put 4 100mmx100mm hardwood fence posts up there one day. This made the car very unstable.
Cheers Pete
On my last trip, going over mountains and some headwinds I averaged 15.5lt / 100
Quite happy with that considering I am pulling around 2800kg and a bit in the back of the tub
Ken
DUN WURKUN
Hi Pete
Thank you for the infor on the roof rack. Ralph.
Ken
 I will be delighted if I can get that rate, Ken. The Prado was 22lt/100k (ouch)
Mike Wharton
Retreat Keppel
Looks remakably like mine! I have a 2" lift plus lounge range tanks (145ltrs). Towing a 2.9 ton Lotus Trooper I get 750km + before I need to refuel. Worth thinking about.
-- Edited by cazbaz on Monday 2nd of February 2015 06:06:31 PM
Yes, our rigs could be twins... I have now fitted ClearView mirrors (black, not chrome). I will get the lift later in the year (once my bank account has recovered from the recent items). The long range tank is certainly another item on the long term list.
What is the ball weight on the Lotus?
Mike Wharton
Retreat Keppel
Ball weight is 270
cazbaz wrote:
Ball weight is 270
Thanks... this is around the same as mine. I thought mine was a bit heavy but it sounds ok... I am certain I will need the suspension upgrade before I tow too far. I am 'land bound' at present and no plans to travel in the near future so I have plenty of time to get it done before I head off...
Mike Wharton
Retreat Keppel
