Post Info TOPIC: descaling a portable toilet
descaling a portable toilet  someone told us vinegar and bi carb soda, but do not know the ratio.as anyone any ideas  your help would be appreciated
The Happy Helper
I would think you would make a paste - well that's what I would do - tried lots of "natural remedies" but none have been perfect so far - think I will try this.
jules
(Ben, aged 10)
it is the tank that nees descaling you would not be able to get to it to use a paste
someone posted recently that they descaled the loo with CLR and it came up like new. I bought some to do ours but haven't got around to it yet. will post the results when done.
Jenny and Barry
If the recipe is vinegar and bicarb using them together would just create a fizzy mix that probably would be useless. The best way would be to use vinegar first to penetrate the scale, say for a day, then add a solution of bicarb. the gas produced (CO2) may then break up the scale and you could flush out the residue. I would think there would be far better products nowadays to fix your problem with various enzyme cleaners available. Again I would leave them to soak for some time then hose out.
Alan
This may be worthwhile praps ?
Add a cup of baking soda, let it sit for an hour.  Then, boil 2 cups of vinegar and dump it into the cassette, run hot water through the cassette to rinse it all out.
Ever couple of weeks we put some milton in the cassette and let it sit for a couple of hours, tip it out, then use our normal stuff. (nappysand) Touch wood so far no pobs.
Straight lemon juice may do some good also. Straight from a lemon or even lemon juice you get in the little yellow plastic squeeze bottles from the supermarket.
on a separate thread about a similar problem - indicator level float blocked in cassette toilet, someone said that once a year they tipped in 2 lt of cheap white vinegar mixed with water and let it stand for the day. They then emptied it out, washed it out 2-3 times to get rid of the vinegar smell and the toilet was sparkling clean.
Havent tried it myself yet.
You can buy products that are supposed to de-scale toilets - google caravan products
Cheers Bruce
Don't have a scale problem - never looked inside - its a toilet. :)
jrg
CLR works a treat about 1/3rd bottle (it was the last of the bottle so I could have been heavy handed )fill with water leave for 24 hrs clean as.
KFT
 X 2, now cleaner inside than out
Avagreatday.
I use citric acid just tip in tank and let it sit  4 a few days when not using it works well
Ive used diluted 10% hydrochloric acid..
If you have a swimming pool ? [at home]
Chances are you have some hydrochloric acid..
Could be a dumb question ... Not used the motorhome yet, but for future reference ...... Is this applicable also to vacuum RV toilets??  So much to get used to after 2years in a camper and our old portaloo was sold with camper never used and in the original plastic wrap!
tks
Libby
The Maccas ....
2013 Avida Esperance Motorhome - based in northern NSW.
Hi Chaslib, we had a vacuum toilet (Dometic VT2500) in our motor home and the cassette  was never descaled but i did give it a good rinse every time after it was used.
We never had any problems with the cassettes ,just everything else.
Vacuum toilets are  great when they are working,  no chemicals, but they are a pain when they play up .
Blues man.
Blues man.
